How difficult to replace valvesprings?
Old May 12, 2009 | 12:19 PM
flintwrench69's Avatar
Originally Posted by tici
Are there advantages using the TDC method?
How low do the valves fall until the piston stop them?
If you are pressurizing the cylinder with shop air, the TDC method wont work. As soon as you pressurize the cylinder, that pushes the piston right back down. If you do not have something to compress the cylinder, then make sure you use the TDC method.
Old May 12, 2009 | 12:23 PM
tici's Avatar
Originally Posted by adam1803
...remove the small springs as they are VERY easy to damage. Just remember to put them back on when your done.
Interesting, thanks!
This is a 98 engine with stock heads and stock cam.
Is there something particular I need take care of?
I'll probably replace springs, seals, rockers and pushrods 'cause the engine has 100'000 miles and makes valvetrain noises + probably valvefloat at high rpm.
I was thinking hardened pushrods, new stock rockers and new stock beehive style springs (like those for the L92)
Old May 13, 2009 | 12:01 AM
2000Hawk's Avatar
I used an air compressor to hold up my valves, and crane cams valvespring compressor which works great. It's not a hard job, even with the engine still in the bay. Obviously #7/8 cylinder won't be as easy as #1/2, but it's not impossible.
-Joel
