MAST Heads
Old May 13, 2009 | 09:04 AM
ls1zfast's Avatar
Default MAST Heads
What do you guys think about these new heads by MAST? Flow numbers are ridiculous compared to other ls1/ls6 aftermarket heads.
http://www.mastmotorsports.com/black...20Heads&id=102
Old May 13, 2009 | 10:13 AM
Mike94ZLT1's Avatar
The prices are ridiculous compared to other LS1/LS6 aftermarket heads! $3600 assembled, and that's WITHOUT the hollow valves or the nitrided dual springs!
However, I would LOVE to see what kind of numbers people put down with them.
Old May 13, 2009 | 10:26 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Keep in mind they are not a cathedral port head like your "other LS1/LS6 aftermarket heads" either.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old May 13, 2009 | 10:42 AM
Mike94ZLT1's Avatar
I am aware of this, but at more than $1000 over the cost of some nice AFR or TFS heads.... these things better put down some SERIOUS numbers! Personally, if I was going to drop that kind of coin on that style head, I would put the money into a new shortblock with a larger bore and just run some CNC ported factory heads.
Old May 13, 2009 | 11:16 AM
Yea, I was more referring to the OP's comment about their flow numbers.
__________________
Old May 13, 2009 | 11:18 AM
allngn_c5's Avatar
Big $$$, big POWER.
Kind of like the ITB Harrop intake.
Old May 13, 2009 | 11:25 AM
Mike94ZLT1's Avatar
Originally Posted by allngn_c5
Big $$$, big POWER.
I want dyno numbers and track results though, flow numbers don't mean **** to me. I understand them, but if they don't make power why spend the money?
Old May 13, 2009 | 11:32 AM
VeTTeMaNC486's Avatar
Big flow means big power, aslong as the runners ain't like 300cc or something lol
These heads would be sick to have, but until the LSXr intake comes out it seems almost overkill, no way a ls3 intake would flow enough to keep up with those high lift flow numbers. Mid lift numbers on those things look sick too...
Old May 13, 2009 | 12:58 PM
allngn_c5's Avatar
I hear ya bro. You have to have flow and velocity, not just flow.
Old May 13, 2009 | 03:28 PM
v8pwr's Avatar
I'd like to see more on these heads myself . I think they'll make the power and be an alternative to ET LS7 head . Does anyone know anything about the casting other than what's online ?
Old May 13, 2009 | 03:35 PM
topher455's Avatar
Big flow is just part of the power combination. When l92 heads came out everybody was frickin gonzo about them. Then guys started loosing power on the bottom of the tach and they werent quite so godly anymore. Im not bad mouthing l92's just making a point. It depends where in the rev range your motor lives IMO.
Old May 13, 2009 | 04:32 PM
SLOC5LS6's Avatar
Im willing to drop the $$$ if these heads put down at least 520rwhp with my 346ci.
Old May 13, 2009 | 04:34 PM
SLOC5LS6's Avatar
bro have you seen the .300-.500 flow ratings...They have some velocity
Old May 13, 2009 | 04:42 PM
9secondsflat's Avatar
they are LS3 heads....not ls1-2....ls3 heads that are cnc'ed by any decent program out flow tfs 215 and 225 heads....big fken deal.....who is bolting them on a 346 ls1 block?????
Old May 13, 2009 | 04:56 PM
ls1zfast's Avatar
MAST is marketing these "small bore" ls3 style heads for 346 applications... definatly and interesting deal.
Old May 13, 2009 | 05:03 PM
Big_Bird_WS6's Avatar
^^^ think this will make the 500 plus 346ci easier to get?
Old May 13, 2009 | 05:09 PM
ls1zfast's Avatar
I would think so.. WIth the right setup. Cam, Intake and supporting mods to take advantage of all that flow. Should be interesting anyways.
Old May 13, 2009 | 05:12 PM
test
Old May 13, 2009 | 05:14 PM
ls1zfast's Avatar
Originally Posted by Big_Bird_WS6
test
test? how so...
Old May 13, 2009 | 05:25 PM
ZMONSTER!'s Avatar
Did anyone else see the 245cc intake runner size? And 2.08 intake valve? Seems WAY huge for a 346. Wouldn't a 245cc runner be better for a bigger (like 402) block? Seems like they would be great for an LS2 stroker, not so much a 346.
