PTV clearence help
Old May 14, 2009 | 08:08 PM
Gregorya24's Avatar
Default PTV clearence help
I have some 241 heads milled to 59cc and a 232/237 613/613 on a 112lsa, i was wondering if im gonna have ptv problems on a stock ls1 rotating assembly im also using stock gm head gaskets. Thanks Greg
Old May 14, 2009 | 08:24 PM
vettett15's Avatar
I'd say that is a pretty sure bet for your pistons to high five your intake valve. I run tsp stage 1 ls6 heads milled to 59cc on a 228/232 cam 113+4 and it is close. Those heads have the valves set back in them i believe.
Old May 14, 2009 | 08:27 PM
brad8266's Avatar
If it clears it will be very close. Measure before you assemble it.
Old May 14, 2009 | 08:28 PM
Gregorya24's Avatar
would yall recommend going to a thick head gasket? anyone know what the cr would be?
Old May 14, 2009 | 08:30 PM
brad8266's Avatar
Id rather have a smaller head gasket for tighter quench area.
Old May 14, 2009 | 08:32 PM
Gregorya24's Avatar
understandable i was plannin on going forged but college budget im just trying to get the car running again, any other imputes guys would be greatly appreciated!
Old May 14, 2009 | 09:18 PM
vsocks1's Avatar
You need to actually measure PTV and I would bet you are in trouble. I have TFS 215's milled to 60cc with a 232/236 .595/.578 113+3 cam and I had 0.040 clearance on intake valve at 11 *ATDC with GM MLS gasket. Many would have just run that setup but we decided to check...good thing! Ended up flycutting my pistons 0.090 on intake so I could run a Cometic .040 gasket to gain compression lost from flycutting and better quench.
Old May 14, 2009 | 09:22 PM
THENASCAR's Avatar
why not just run that setup with MLS gm gaskets and flycutt for both valves??either that or clay it. either way i would check. ur college budget my fly right out the window when it needs a new motor. either that or go with a smaller cam
Old May 14, 2009 | 09:30 PM
Gregorya24's Avatar
guess ill check the ptv clearance as it sits now and if i dont clear i will try a thicker head gasket before i get the stock pistons flycutted
