Valve spring tool
Old May 19, 2009 | 02:54 PM
Tom@SpeedInc's Avatar
Default Valve spring tool
After careful development we now have brought this tool back to the market, for a better price. Cut your spring installation time in half!
$119.99 shipped
NOW AVAILABLE FOR ONLINE PURCHASE
http://www.speedinc.com/cont.cfm?cid=C0000900
For ordering can email me fraser@speedinc.com
otherwise check with any of our sales reps here for ordering
Heres whats included
- works for cathedral port 15º style heads only
Old May 19, 2009 | 04:23 PM
vettenuts's Avatar
Two questions. Are you making these yourself? If so, have you considered modifying it so it works with other heads (AFR, etc.). I have the original and modified so it worked on my previous Dart heads and my current AFR heads. Still works on GM heads. Just seems the market would increase with this capability.
Old May 19, 2009 | 04:25 PM
davered00ss's Avatar
Moderator
Will this work on AFR 205's?
Old May 19, 2009 | 04:27 PM
The tool is made on a 4 axis machine about a 7 iron shot away from where i'm sitting right now.
With sales volume will determine if we should make other versions, however we are rather flexible, I think an L92/LS3 would be next version available.
Old May 19, 2009 | 04:28 PM
I believe vettenuts posted he modified his to work with AFR heads?
Old May 19, 2009 | 04:31 PM
Heres a pic of it installed, works on car/off car
Old May 19, 2009 | 06:44 PM
vettenuts's Avatar
If it is machined the same as the old Crane version, not out of the box. But a little time with a grinder will fix it so it will. The issue on the AFR's is the larger boss where the valve cover screws in.
Old May 19, 2009 | 08:06 PM
Hi-Po's Avatar
Holy ****, that is awesome. WAY, WAY better then what I used.
Old May 19, 2009 | 08:28 PM
405HP_Z06's Avatar
Happy to see these didn't go away with Crane. The best spring tool.
Old May 19, 2009 | 10:14 PM
phoenix's Avatar
i got one of these at the shop, we had modify it to work on LS3 cars, and works great! this is a must have tool for anyone changing springs on an LSx motor. i would like to see someone come out with an valve spring tool for the LS7 heads!
Old May 20, 2009 | 12:00 AM
brianfromhawaii's Avatar
What about making a peice of metal that sides under it so it doesnt press down on the piston or whatever your working on
Old May 20, 2009 | 12:05 AM
99blancoSS's Avatar
It sits on the heads and attaches to the rocker bosses, its a great tool I've had my Crane for about 4 years now. Great idea of Speed Inc to revive it best tool on the market for doing a spring swap.
Old May 20, 2009 | 12:58 AM
doesn't affect the pistons, the valves are held in place by air pressure. When Swapping springs in car
when using on a workbench a shop rag positioned under the combustion chamber is all thats needed.
thanks for your comments Chris
Old May 23, 2009 | 07:12 PM
mrr23's Avatar
did you buy the rights to the crane tool when they got auctioned off? i know you guys and crane had a few ties. it's cool that you did revive the tool.
Old May 23, 2009 | 08:19 PM
SweetS10V8's Avatar
Exactly what I was going to ask....
Old May 23, 2009 | 09:32 PM
98Aggie's Avatar
Moderator
Glad someone is picking up this tool. If I had a L92 and a LS7 head (or dimensions) I could get my friend to draw up a new spring tool up in Solidworks or Pro-E to use on these heads unless you have already started doing that.
Old May 23, 2009 | 10:05 PM
ZMONSTER!'s Avatar
subscribed-will buy one shortly
Old May 23, 2009 | 11:32 PM
L92 can probably be done with a little work
LS7 spring tool would be difficult to make, the rocker bosses are kind of a cluster. 12º valve angle will leave you starting at scratch.
We made this on mastercam, its not easy as it looks, a few unit runs are not worthwhile, we had 100 of these made first run.
Old May 23, 2009 | 11:35 PM
Old May 24, 2009 | 12:10 AM
mvvette97's Avatar
I had to modify my crane to fit the large retainers. I don't remember what I paid for the crane but this seems like a much better deal.
