220/220 would be more streetable than 224 right?
Re: 220/220 would be more streetable than 224 right?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
<strong> i have the comp 224/224 .563 114 cam and im more than likely gonna yank that cam after spring. I need something a tad more streetable than what i have now and i was leaning towards a 220 cam.
any ideas? opinions?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">As far as I know, the idle quality and streetability of a cam are determined by the overlap (the amount that intake and exhaust valves are open at the same time).
My 224/224 0.581/0.581 114LSA has steep lobes that lower the advertised duration. I think it's advertised duration is around 275 degrees, while a MTI B1 or T1 has over 280 degrees, even though they only have 221 degrees at 0.050" of lift. I think the 224 XE lobe (which you have) also has about 5 more degrees adverised duration than mine, and that the XE lobes don't get down to 275 degrees advertised duration until you go to a 218 or 220.
You'll have to check the numbers for yourself, but to help idle and streetability, find the smallest advertised duration you can. You want to keep you duration at 0.050" high, to make good power.
The downside of getting a cam with steep ramps is that it makes the valvetrain louder (sounds like a sewing machine), and that it's harder of valvesprings.
Good luck,
Miles
Good luck,
Miles
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Miles in Michigan:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 98TAauto:
Good luck,
Miles </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thanks for the info! Thats one thing I dont like about my 224 cam. It sounds like a damn war on the valvesprings <img border="0" alt="[shoot]" title="" src="graemlins/gr_guns.gif" />
Good luck,
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by StreetStalkerZ:
<strong> The B1 cam will make you go faster <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">anyone know how much of a HP difference there would be in the 224 and 220 or 221 cams?? im guesing not much... i dont want to loose the power of the 224.. but ill be more than happy loosing 5-8hp but having a better daily drivr
I beleive Slowhawk gained 10 hp going from TR220 on a 114* to a TR224 on a 112*. You should be able to sort out surging with tuning and no cam change.Especially on a 114* lsa, dont give up power when you dont have too big a cam to begin with, IMO of coarse.
Come on Harold, sack up. You got a muscle car, whats wrong with a little surging. <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> If anything you might want to consider a bigger cam for when the track opens. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" /> <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> See ya in March if we ever get rid of all this snow. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Bruce
Bruce
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Hardtop:
<strong> Come on Harold, sack up. You got a muscle car, whats wrong with a little surging. <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> If anything you might want to consider a bigger cam for when the track opens. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" /> <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" /> See ya in March if we ever get rid of all this snow. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Bruce </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">im just getting info on future options <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
i may be able to put up with the off and on surging, but time will tell... hell i dont think any tracks are gonna be open in March with this 2-3ft of friggin snow on the ground <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Comp xe 224 cams are 277 advertised. Keep playing with edit brotha, you can make that thing work. My 110lsa cam doesn't surge although I do have a six speed. Do you have a stall, I would guess yes. Through some gears in there in that will help also. Good luck.
vig3600... my car always seemed to idle funky even before the cam after i put that converter in...
oh well, after i kick some M6 butt at the shootout on May 3rd i may keep the cam <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
HD: I had no surge issues with the same 224 cam. I did use higher shift & lock-up points than stock. You probably just need to fiddle a bit more once the snow melts and raise lock up speed a tad.
A while back Paul at TR told me the 224 was worth around 5 ft-lbs and 5 hp over the 220. That's throughout the powerband, so it won't be a huge hit, but there will be a loss similar to taking off a bolt-on mod.
The TR 220 cam will be a little more street friendly. I had a 218/218 XE cam and it was very smooth. The TR220 with its faster ramps should be as smooth as my old 218 cam.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ragtop 99:
<strong> HD: I had no surge issues with the same 224 cam. I did use higher shift & lock-up points than stock. You probably just need to fiddle a bit more once the snow melts and raise lock up speed a tad.
The TR 220 cam will be a little more street friendly. I had a 218/218 XE cam and it was very smooth. The TR220 with its faster ramps should be as smooth as my old 218 cam. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Joel, thanks for the info.. Ill probably stick with the 224 untill i have to switch out my valve springs and then i may put the 220 in there just to have a more friendly daily driver <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> thats if i can get my little issues with the 224 sorted out. Again I dont have any major probs with the 224 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
i have the comp 224/224 .563 114 cam and im more than likely gonna yank that cam after spring. I need something a tad more streetable than what i have now and i was leaning towards a 220 comp cam or TR220. Also the B1(221/221) looks possible.
the 224 cam is great, but im getting sick of the surge that happens off and on. Even with edit I cant get things the way i want them <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ February 16, 2003, 01:09 PM: Message edited by: 98TAauto ]</small>
Hey Harold
I have the TR220 . I still get some surging every now and then. I noticed it more when i had then ported maf ends in. Not sure but it seems so be better with the stock maf but i still get some surging. I would probly get a set of heads and keep that cam is i was you <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> . I think im gonna move up to 227 or 228 cam. If ya want to wait like 6 weeks ill give ya a nice deal on mine. or a trade or something. let me know.
Jeremy
Jeremy
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by offaxis:
<strong> Hey Harold
Jeremy </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Jeremy, hit me up when you take that cam out. I may be interested, but i may just keep the one I have. Im undecided right now
<strong> Hey Harold
