LS7 in an F-body pics
Old May 26, 2009 | 02:17 PM
  #41
Mavmavv's Avatar
I'm loving the stock look.
"Yup just a 224 cam and a set of SLP headers. I'm trying to save money right now to get an underdrive pulley."
Haha, use this line.
Old May 26, 2009 | 02:25 PM
  #42
rjt2291's Avatar
I'm so turned on right now. Can I take it for a ride?
Old May 26, 2009 | 04:52 PM
  #43
IT_SS's Avatar
Originally Posted by red02Hawk
well i finished my build a month or so back, finally got around to taking some pics. The engine has around 450 miles on it so far, I've only had her to around 4500 rpms and this thing is an absolute BEAST. Does the engine compartment look too stock, do i need to put a huge LS7 decal on the intake? Or do you like the look, i tell most ppl, "I just got a cam"
It looks good, the only thing that would stand out is the intake manifold....but you would have to know the LS engine family to see the diffrence
i love the car !!!!
also, where did you put the oil reservoir? I noticed the battery is still in its stock position
Old May 28, 2009 | 12:49 AM
  #44
metalmechanic's Avatar
ah that aint shot, looks just like my LS 1
Old May 28, 2009 | 10:58 AM
  #45
GreenBlood's Avatar
nice setup!
Old May 28, 2009 | 01:49 PM
  #46
jmilz28's Avatar
yep stock oil pan, its a street car so the wet sump will be fine. I've only got about 600mi on it now so no dyno numbers or track times. As for weight distribution, i think the ls1 and the ls7 weight pretty much the same.
What route did you take to make it wet sump? Isn't the crank snout different? Oil pump? Give us some details and costs on this piece if possible. This setup is AWESOME, almost totally stealth, dig it!
Old May 28, 2009 | 02:15 PM
  #47
XTrackStar06X's Avatar
did you have to have any custom work done for the motor to fit? what tranny are you running with that? im just as curious as the other on the wet sump setup. ive been toying around with this idea of an LS7 swap and would like more info if possible from OP
Old May 29, 2009 | 02:25 AM
  #48
red02Hawk's Avatar
its a resleeved ls1 block, so i didn't have to mess with any sensor adapters (other than the MAP sensor). The motor fits perfect, not mods needed. I thought i might run into some problems along the back of the intake, it has a little less clearance than an ls6 intake. The rotating assembly is just LS1 style(reluctor wheel, crank snout) but the pistons are specifically made for LS7 head(correct valve reliefs). $$$$$ lots and lots of it, would have been a little more to get a crate motor, but it wouldn't have the high end aftermarket parts i wanted.
Old May 29, 2009 | 04:40 PM
  #49
BlkBird2000's Avatar
I think you should get the new 104mm lid and maf from Fast toys performance... I think you would gain some hp.
https://ls1tech.com/forums/generatio...order-now.html
Old May 29, 2009 | 05:39 PM
  #50
05 GSXR 1XXX's Avatar
love it!
Old May 29, 2009 | 06:48 PM
  #51
JDM74's Avatar
Looks good and too any one that is not LSX motor "in the know" they would never know the difference.
The things that indicate that "something is afoot at the circle K" are:
The MAF
The intake manifold
The fuel rails
The head casting number on the driver side head
the throttle cable/ cruise control cable bracket
The 4 bolt throttle body
But, like I said, those would only be noticeable to the LSX enthusiasts.
Old Jun 9, 2009 | 01:02 PM
  #52
z28camaross's Avatar
whats needed for an ls7 swap?
Old Jun 9, 2009 | 01:18 PM
  #53
Fb0dy0nly's Avatar
And throw on the Fast Toys Ram Air Kit as well. Both of these would help that engine breathe much more effiencent and the ram air kit hides well and wouldnt even be seen unless someone gets under your car to keep with the stock appearence of course.
Old Jun 9, 2009 | 01:23 PM
  #54
01badz28's Avatar
well its not a crate motor but i do have probably around 21k total, in the car (car, engine, trans, wheels, etc)
Man, that is down right creepy. Except for the chrome wheels, our cars are nearly identical, almost down to the engine bay (mine is only an LS3 though). Those polished LS2 / 3 fuel rails are a dead give away that ain't an LS1.
Great minds think alike, nice looking ride!
Old Jun 9, 2009 | 03:47 PM
  #55
brians91formula's Avatar
can you please please please post some videos of this beast soon ? I would love a cammed ls7 setup in my trans am. /drools
Old Jun 9, 2009 | 09:58 PM
  #56
mred's Avatar
The MAF
The intake manifold
The fuel rails
what in the hell did you just say
Old Jun 18, 2012 | 06:52 PM
  #57
BlackNiteWS6's Avatar
Well done!! Very nice work. It looks like the car came that way from
GM...Go have some fun
Old Jun 19, 2012 | 08:18 AM
  #58
totalchaos's Avatar
love it
Old Jun 19, 2012 | 09:10 AM
  #59
shadyLS6's Avatar
+ 1 nice work.. hope i never see this sleeper on the street and get crushed
Old Jun 19, 2012 | 09:17 AM
  #60
MasterTomos's Avatar
First glance at a car show and I would just assume it's an LS1...very cool.
