PLEASE HELP!! Hella engine ticking noise
Then call/e-mail some companies and compare that to the price of a forged shortblock.
Then make your decision.
Yea, I'll go to the other machine shop tomorrow (well couple hours later) and get some idea/info. That's the same shop who did the port head for my friend. I mentioned that a while back if you guys remember.
BTW, stun a rod bearing should not damage the block right, in theory? After that performance shop guy told my friend about his block, he's kinda worry now. He's don't wanna rebuild the block now and couple months later it got problem.
Pred-Z, can you kindly explain some scenario here? Like will the old block be reusable for rebuild? Are you recommend reusing it? I'm gonna show this thread to my friend so he know what's the REAL expert recommended.
i think what everyone is saying is do it right, forge it etc, or you/owner will be back in 6monthes to a year redoing everything.
do it right, get the right parts, built it correctly, or have someone who knows how to do it do the work.
I drive out for a tune and easy on the everything. The idle is fine and drive good, no misfire and KR. Then do some change to the tune for a second run. This time I rev it to 4500~rpm and shift. It runs ok but there's some ticking noise coming from the head area.
Go home, open the valve cover and check, nothing wrong. Fire it up again, now the noise is louder. Even at idle the noise is very noticeable. Also, the oil pressure gauge stays at 60psi all the time. After the second run, now the oil pressure drop to 40psi at idle. Give it some gas it'll jump up alittle.
Long story short, did the 4500rpm run fxxk that something up or the tune? What should I check for those ticking noise?
And are you just a backyard mechanic working on this guys car? If so i really hope that you are paying for what you messed up.
Hopefully the head is ok. Also, since cylinder 1 and 3 are on the same crank throw and chances are they both were smacking the head, your crank may be FUBAR as well (just as mine was), this is due to the crank trying to rotate thru its circumfirance and all the sudden the piston thats connected to it suddenly wants to stop when it hits the head, and that puts huge force on the crank.
Have the crank magnafluxed at the least, or just toss it assuming its screwed, which it probly is. Sounds like time for a stoker!!
And like everyone says, do it the right way.
When the shop said that the rod bearings had spun, did they mention material in the oil, things that look like they used to be piston rings??
backyard tuners F T L
