PLEASE HELP!! Hella engine ticking noise
Old Jun 9, 2009 | 04:07 PM
  #61
edcmat-l1's Avatar
Spun bearings won't cause smoke out of the oil filler cap. That's a broken piston, and quite possibly due to a tuning issue. Sorry to be the bearer of bad news.
Old Jun 10, 2009 | 02:12 AM
  #62
XZ28X's Avatar
Originally Posted by darknessxyz
Yes but I don't feel like telling you that. You just one of those fanboy with nothing help to post. I don't even know why I response. It's a slame for me.
Im just trying to point out that it could be your tuning that is the issue here, since you said it only started making noise after you messed with the tune and revved the engine to 4500rpm. If it was an oiling issue i think that it would have started making noise before you had a chance to tune it.
Old Jun 10, 2009 | 02:13 AM
  #63
XZ28X's Avatar
nuff said
Old Jun 10, 2009 | 02:37 AM
  #64
1Loudz28's Avatar
i still want to know what the shop said.
Old Jun 10, 2009 | 02:46 AM
  #65
lemons12's Avatar
It's not the tune (so i keep telling myself). I've had a hand full of people ,that have about as much knowledge of tuning as i do, verify that already. Stop the bitching at me because i screwed up and please post useful info mechanical related so it looks like i didnt mess up.
fixed...
Old Jun 10, 2009 | 02:54 AM
  #66
darknessxyz's Avatar
So you guy know how to tune? Ever owned a HP Tuners or EFI Live or something?
Old Jun 10, 2009 | 02:55 AM
  #67
Originally Posted by lemons12
fixed...
Can you tell me what do you know that can help?
Old Jun 10, 2009 | 02:56 AM
  #68
SMOKNSS's Avatar
Just tell your buddy to go ahead and forge the motor since he' s gonna have to tear it down anyway. Then take it to a SHOP to get it tuned.
  #69
XZ28X's Avatar
spun bearings won't cause smoke out of the oil filler cap. That's a broken piston, and quite possibly due to a tuning issue. Sorry to be the bearer of bad news.
this is what is wrong!!!!! This guy uses all those tuners and just told u its fucked up!!!!!!
Old Jun 10, 2009 | 02:58 AM
  #70
XZ28X's Avatar
If your read as bad as you type your in trouble but it is spelled out in the post by edcmat-l1
Old Jun 10, 2009 | 03:01 AM
  #71
lemons12's Avatar
no, i know just as much as you do about tuning obviously..
therefore, i paid 300$ for my first tune.. and 150$ for every following retune..
my car runs perfect.. i have an awesome tuner, ill leave the tuning to him.
  #72
Again, if any of you expert know anything about tune, I can send you my tune file and scan file. So you can point a finger on me. However, it's useless cuz I don't even think all your expert have HP Tuners software.
If you're not help, please keep it out.
Old Jun 10, 2009 | 03:04 AM
  #73
That means non of you guys can contribute any helpful info, I gues that's it.
Old Jun 10, 2009 | 03:05 AM
  #74
Also please don't turn this into couple pages of useless crap.
Old Jun 10, 2009 | 03:07 AM
  #75
XZ28X's Avatar
your sidestepping the above post by a legit tuner
Old Jun 10, 2009 | 03:08 AM
  #76
lemons12's Avatar
just in case you missed it.......
Old Jun 10, 2009 | 03:09 AM
  #77
XZ28X's Avatar
and how would the engine start knocking all of a sudden after a 4500 rpm pull if it wasnt tune related???
The motor was bad already and you shouldnt have worked on it???
Old Jun 10, 2009 | 03:30 AM
  #78
XZ28X's Avatar
It seems like your also not an expert asking alot of questions while your doing the work.
https://ls1tech.com/forums/pcm-diagn...t-way-off.html
something you should have known prior to trearing it down
https://ls1tech.com/forums/generatio...-pre-load.html
and then another issue ur having with the car who knows if you ever fixed this issue??
https://ls1tech.com/forums/pcm-diagn...dont-work.html
Old Jun 10, 2009 | 05:58 AM
  #79
edcmat-l1's Avatar
Let me clarify before everyone piles on.
The tune doesn't have anything glaringly obvious that could have caused catastrophic failure. But, the failure of a piston IS the most likely cause of the excessive crank case pressure. AND, the most likely cause of the broken piston is detonation. AND, the most likely cause of detonation is a lean condition and/or excessive timing, and/or a combination of both.
If it is indeed a piston failure, it had to be caused by either a tuning issue, or a piece/part of something that ran through the engine. It's awfully hard to say before taking it apart.
Unfortunately, sometimes crap like this happens.
Old Jun 10, 2009 | 08:30 AM
  #80
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
First off, is this your car, or is it someone else's that you are working on for them?
I understand you wanting to defend your tuning ability. But, it seems really "coincendental " that you work on the car and re-tune it, and the first time the car would probably go in PE the motor "pops". Hmmmmmm
Now, it could be that something broke on its own, or it could be that it was just time for something to go out. But, the first rule of troubleshooting is to look at what last changed, and go from there.
While you were working on this car, did you pull the injectors. Is there any possibilty that you got the injectors swapped around or the wiring to an injector.
Were you logging A/F on the car? Do you know what the A/F was at the time of the issue?
It may not be the tune, you might have sucks a nut or a small screw into the motor also. You could kill a piston, crack the liner, etc... Really you need to pull the motor down and see what is going on. You can't fix it in the car more than likely. So, your options would be to see if you could find a replacement engine cheap, or fix that one if its salvageable.
If a piston is hurt, or there is any gouging in the cylinder wall you need to ensure the liner in the old motor is ok before you spend any time on it. Otherwise it may be a junk block.
Also, don't get so defensive when folks suggest the tune might be to blame. Its certainly the first place to look when you pop a motor and it looks like it went lean to do that...
Goood luck.
Btw, the word "hella" makes you come off as some sort of F&F ricer...
