helpp! problems after cam install
Old May 25, 2009 | 07:27 PM
brokeLS1owner's Avatar
Default helpp! problems after cam install
put in ms4, prc duals melling oil pump and hardened pushrods. put it all back together. started her up and had to feather the throttle to keep it runnin. it ran for about 5 minutes with oil pressure at like 70 which seemed high to me and i heard a pop folllowed by white smoke. looked under the hood and the valve cover gasket was blown completly out of place. idk what to do so please help me out guys
Old May 25, 2009 | 07:35 PM
willyfastz's Avatar
Restricted User
Did you pull the valve cover off and take a look? The oil pressure didn't just blow the valve cover gasket out.
Old May 25, 2009 | 07:40 PM
i havent pulled it off yet im lettin it cool down, just wondered if anyone had any insight onto why this would happen, i know i tightened the bitch down so somethin obvioulsy aint right. also the service engine light is on. idk if thats normal too but it was off before
Old May 25, 2009 | 07:45 PM
mike13's Avatar
sounds like your engine isn't venting crankcase pressure.
Old May 25, 2009 | 07:50 PM
so how do i fix this?
Old May 25, 2009 | 07:57 PM
eallanboggs's Avatar
If PCV is clogged or stuck shut it won't vent back to the intake and that pressure has to go somewhere.
Old May 25, 2009 | 08:02 PM
Greg Pippin's Avatar
I want to see where this goes.^^^^
Old May 25, 2009 | 08:08 PM
ok well im still looking for suggestions on what to look for and change. all i know about pcv is that its like little plug that goes into back of the valve cover lol. and where is this gonna go pippin?
Old May 25, 2009 | 08:09 PM
1Loudz28's Avatar
depending on what year ur car is, the valve is above the passenger side valve cover.
Old May 25, 2009 | 08:12 PM
99 and what should i do with the valve
Old May 25, 2009 | 08:32 PM
If the valve cover blew out then the engine aint venting good, like what {ellanboggs} said..But for the white smoke, you will usually see white smoke if you are burning oil or coolant.
Did it get hot ? ?
Old May 25, 2009 | 08:49 PM
willyfastz's Avatar
Restricted User
Pull the valve cover off already.
Old May 25, 2009 | 09:18 PM
1Loudz28's Avatar
buy a new one. theyre like $5. but yeah, pull the valve cover.
Old May 25, 2009 | 09:24 PM
buying a new valve cover and figured out my problem, i didnt plug in my coil pack on the passenger side, im such a dumbass like that. thanks for the help guys
