Just want to verify this:
Old May 28, 2009 | 09:13 AM
letsrunem's Avatar
Default Just want to verify this:
Coolant in the oil can only come from 3 places: (assuming you didnt pour it in the oil fill hole)
Cracked block
Cracked head
Blown headgasket
I bet you'll never guess why I'm asking
Old May 28, 2009 | 09:24 AM
conan's Avatar
You are correct. Sorry you have to ask this question. Also if you have forced induction you can lift the heads with too much boost and get coolant in the oil that way.
Old May 28, 2009 | 09:32 AM
letsrunem's Avatar
I wish I had a chance to see boost with this motor. Brand new, idle time only, never got to spin the TC78.
Old May 28, 2009 | 09:39 AM
Fireball's Avatar
what headgaskets? had same issue with cometics a few years back...never sealed on first try and water ended up in oil just idleing
Old May 28, 2009 | 10:12 AM
letsrunem's Avatar
Wow that's crazy. Might as well have o-ringed them with spaghetti noodles lol. I'm using 6.0 MLS headgaskets for my 317s.
Old May 28, 2009 | 10:55 AM
letsrunem's Avatar
Question: This is my first new motor, should the oil be pretty dirty the first time you change it? Like moderately dirty? I'm not sure if I'm seeing milkyness or just new motor break-in stuff.
Old May 28, 2009 | 12:23 PM
hirdlej's Avatar
Or if you have an integral oil cooler in your radiator. LT1 B-bodies have this problem a lot when the fittings crack in the tank.
Old May 28, 2009 | 12:26 PM
conan's Avatar
How long have you run the engine since you assembled it? Was the block deck checked by a machine shop. The GM MLS gaskets are a very good gasket, and alot more forgiving then cometic's MLS.
