5.3 forge pistons
Old May 30, 2009 | 03:39 AM
Chente's Avatar
Default 5.3 forge pistons
ok guy I know this is a f-body but I am also going to post it in pt I am trying to find some flat top forge pistons for a 5.3 trying to prove a point that this little engine run strong I am currently running a 5.3 with low compression well 9.5 and running 13.0 to 13.3 on an off but cant pick up my dynamic compression due to the dish piston. thanks for any help cant go over 8.0dcr
the currently set up is a 220 224 112+2 on a 2005 truck fullbolt on mad 345 hp on a mustang dyno and 343 tq
thanks again
Old May 30, 2009 | 09:40 AM
5.3LJimmy's Avatar
Up until a year ago there were none available off the shelf. I think it's Wiseco that just started producing them. You also have the option of 4.8 liter pistons or 07-up 5.3's, which both have flat tops from the factory. I'm gonna search and verify whether or not Wiseco is the correct manufacturer.
Old May 30, 2009 | 09:42 AM
5.3LJimmy's Avatar
Here you go: https://ls1tech.com/forums/generatio...s-pistons.html
Old May 30, 2009 | 12:36 PM
Chente's Avatar
Originally Posted by 5.3LJimmy
thank you man
