Anyone use these rod bolts?
Torque on the head of a fastener has a lot of variables, surface finish in the threads of the fastener and what it's fastening, as well as on the underside of the head and the surface the head is landing on, as well as the type, amount, and distribution of lubrication on assembly, cleanliness...it goes on and on...are all variables that affect the torque measurement on the head of a fastener.
Stretch on the other hand, has much less for variables...quality of the material of the fastener and consistency of that material from fastener to fastener...when you use high quality fasteners (rod bolts are a good place to use high quality fasteners), the amount that they stretch during installation is 100% directly correlated to the tension on the fastener. The only real issue with stretch as a measurement of pre-load is when you don't know how many times a fastener has been installed and uninstalled...as it is possible that it has been damaged...but that will affect torque readings too.
Degrees of rotation on a fastener can be a good way to properly measure tension on the fastener as well...but it has it's issues too (but I like it when working with blind holes where I can't measure stretch).
Now lets say I slowly moved the tourque wrench readings up until I found the point were the stretched fastner wanted to give. If all the bolts took the same reading there should be no issue and I can have peice of mind. If one bolt does not take the same applied force, I know there is a problem with that fastner. In this case that one bolt still wanted to turn even with 5 Lbs less of applied force while all other bolts maintained the same amount of strech with the force applied. That tells me there is some sort of an issue with that fastner.
For me, Just knowing that one bolt had an issue and could cause a catastrophic Faliure of my new motor. I am more then satisfied that I caught a potential problem now before I ruined some expensive parts.
It's taken me over a year to scrape up the extra money after all my bills are paid to buy all the parts and pay for the machine work for my replacement motor. It may not be a Twin turbo motor using an LSX block but since it's going in my DD, I want to get my money's worth out of it. I can't affoard to do it a second time.
edit: I meant the second link from this post on the first thread page. oops
Factory Rod Bolt Identification- http://www.enginebuildermag.com/Arti...u_engines.aspx
BUt then again, they're post '02 motors. doh !
Revised Rod Bolt Tightening Procedure- http://www.enginebuildermag.com/Arti...rod_bolts.aspx
Those look like the 2nd or 3rd design so 15 lb ft of torque and 85 degrees.
Since the above links no longer work, The good people of summit have and identification chart.
https://help.summitracing.com/knowle...SR-05186/en-us
