Engine tick when car warms up.
You need to check preload.
how hard is it to check for PR length and pre-load?
after you do a cam swap you should NEVER just put in stock length or any rods for that matter or even take someones word for it, BUY A CHECKER AND MEASURE !! PERIOD !!
As to the OP are you aware that you are going to have a certain amount of valve train noise when you go to a aftermarket cam and upgraded springs...it will never be as quiet as it was when the car was stock....after 190,000 LS series engine miles I ought to know...with the TR230 cam you should be alright with the 7.4 pushrods...but for your peace of mind you should go ahead and check the preload...buying parts and throwing them at the engine without a valid reason is not smart and just a waste of your hard earned $$$ ... that is how you can tell a good mechanic from a parts changer ... work your head and your plan before you invest in new parts..you will save time and money in the long run.
It really doesnt matter what Thunder Racing says, you need to check preload when you change the cam...always...no matter what anyone says. Otherwise why spend all that money on a good valvetrain when its just going to eat itself because you didnt take a half hour the verify the correct preload on the lifters.
but if I were to diagnose the TS's problem it would be that the lifters need to be replaced.
put a cam in, it blew one of my LS1 lifters... it was very distinct, very loud and nerve wracking. i put in a new set of LS7 lifters and the CLACK noise changed, got a little quieter but didnt go away. then it started to get distinct again, i could hear 2 lifters making more noise than the others.
just replaced all 16 LS7 lifters AGAIN yesterday, noise is still there, but a little more muffled. its not exhaust, its making me crazy and im going to measure my preload as soon as my PR checker arrives.
i have no idea what could be causing the damn noise, though.
Agreed & the bolded part is what I think alot of people miss. they expect to change up the valvetrain, add a more agressive cam & it still be quiet as stock, which isn't gonna happen.
