Oil for LS1.???
Old Jun 18, 2009 | 01:38 PM
brians91formula's Avatar
I was using Castrol Edge 5W30 and liked it ok. I then switched to German Castrol 0w30 with a K&N Gold filter. I have heard great things about the GC thats why I switched.
Old Jun 18, 2009 | 02:02 PM
IT_SS's Avatar
Mobil 1 High Mileage 5w-30 & Mobile 1 filter
Old Jun 18, 2009 | 03:35 PM
s346k's Avatar
valvoline 5w30 seems to do ok. regular of course, none of that synthetic **** haha.
Old Jun 18, 2009 | 03:48 PM
Mumbles's Avatar
Mobil 1 Synthetic 5W-30 with AC Delco PF46. No troubles here.
Old Jun 18, 2009 | 05:15 PM
Bill Bowling's Avatar
German Castrol 0w30. Been using it for years. They just had a sale at AutoZone. It was $25 for 5 qts and a K&N filter.
Bill
Old Jun 18, 2009 | 08:05 PM
highgear's Avatar
WalMart Super Tech 5w-30 and the WalMart filter 3506. Very good oil pressure. This is on my DD.
Old Jun 18, 2009 | 08:17 PM
TransAm11973's Avatar
Originally Posted by camarobid
What is the best option for LS1?
1) Royal Purple 5 - 30 + Lucas Heavy Duty Oil Stabilizer = (4 + 1)
2) Royal Purple 10 - 30 + Lucas Heavy Duty Oil Stabilizer = (4 + 1)
3) Royal Purple 10 - 40 + Lucas Heavy Duty Oil Stabilizer = (4 + 1)
4) 100% Royal Purple 5 - 30 = (5)
5) 100% Royal Purple 10 - 30 = (5)
6) 100% Royal Purple 10 - 40 = (5)
dont use any of these , RP is a horrible over marketed oil. Has bad UOA's. As for Lucas Oil Stabilizer , that stuff is crap as well. All it will do it make your oil maybe thicker and change its chemical make up. Your best bet is to use Penzoil Platinum. Its a true synthetic, not a blend and has great UOA's. If you dont mind spending the money then use Amsoil, its top of the line. No matter what oil you go with dont use Lucas...
Old Jun 18, 2009 | 08:21 PM
purdueranger's Avatar
You guys aren't going to really like this one but
M1 15W-50 with M1 filter.
Old Jun 18, 2009 | 09:13 PM
crainholio's Avatar
M1 15W-50 here as well, Baldwin oil filter. I beat the **** out of mine on Pocono Raceway's road courses and Lime Rock Park at 30+ minute sessions at a time, that 5W-30 crap turns into water when it gets past 250degF temp for any amount of time.
For poseurs who only use theirs on the street, 5W-30 is fine whatever brand.
Old Jun 18, 2009 | 10:58 PM
Lethal Z's Avatar
M1 5w-30 here.
Thought about switching over to the penzoil platiunm but its the same price as the mobil one. Why switch.
Old Jun 19, 2009 | 12:44 AM
raysadude's Avatar
AMSOIL 0w-30 here and AMSOIL filter..they're expensive $11 per quartz but i've never put anything other than AMSOIL in my car
Old Jun 19, 2009 | 02:34 AM
  #32
BriancWS6's Avatar
Where's the "none of the above" option?
From UOAs, which is what matters, Pennzoil Platinum 5w30 is one of the best readily available oils for these cars.
Old Jun 19, 2009 | 03:29 PM
  #33
for posers? Only use theirs on the street? What are you talking about?
Old Jun 19, 2009 | 04:03 PM
  #34
Cruzer23's Avatar
My dad uses valvoline 10w-40 and when people tear his engine down, they immediately ask what oil he uses because its so clean.
Of course that is just for regular stock engines.
If your going for synthetic i would go with valvoline's synthetic, im sure it does the same work on your performance engine.
Old Jun 19, 2009 | 04:23 PM
  #35
You got to be kidding....
Old Jun 19, 2009 | 05:04 PM
  #36
Pharcyde50's Avatar
GC with 1/2 bottle of lucas break in additive and a wix filter
Old Jun 19, 2009 | 07:24 PM
  #37
camarobid's Avatar
waaaaa?
Old Jun 19, 2009 | 07:30 PM
  #38
this is a horrible idea, amazes me how much people on this site really dont know anything about cars or engines
Old Jun 19, 2009 | 07:38 PM
  #39
dragonrage's Avatar
GC, Bosch filter. Oversized filter if you're not lowered, IMO, #3423. It will stick out below the oil pan by a little bit. Never a problem in my opinion. If you don't like the idea then go with a Bosch filter, whatever the regular size one is.
RP isn't bad but it's overrated. GC is better.
Stay away from Lucas either way.
Old Jun 19, 2009 | 10:36 PM
  #40
Pharcyde50's Avatar
The break in includes zinc and other metals that can only be added in small amounts to off the shelf oil. Zinc acts as an anti wear additive but I guess it doesn't mix with cats too well. Oh I've also built my car in my garage from the ground up! I might know just a little bit.
http://www.hotrod.com/pitstop/hrdp_0...ive/index.html
