Oil for LS1.???
Old Jun 20, 2009 | 01:09 AM
  #41
Anthony Williams's Avatar
Thumbs up
Shell Rotella T 15w 40, K&N 6L truck filter 157k miles, great oil pressure 40 psi @ idle. I really don't think you can go wrong with any name brand oil, changing the oil and filter at regular intervals is whats important. I change mine EVERY 5k.
Old Jun 20, 2009 | 01:16 AM
  #42
Trans Am Jam's Avatar
ROYAL PURPLE SUCKS!!! they are being sued for false advertisement. run Mobil 1 10w 30 or 5w 30 like i do.. they are proven to be the best.
Old Jun 20, 2009 | 01:31 AM
  #43
blakern's Avatar
original oil in mine, i just strain it out every 3k and put it back in. no prob yet??
Old Jun 20, 2009 | 08:41 PM
  #44
TransAm11973's Avatar
Originally Posted by Pharcyde50
The break in includes zinc and other metals that can only be added in small amounts to off the shelf oil. Zinc acts as an anti wear additive but I guess it doesn't mix with cats too well. Oh I've also built my car in my garage from the ground up! I might know just a little bit.
http://www.hotrod.com/pitstop/hrdp_0...ive/index.html
its called "break in" for a reason. It should be used for break in, and this is mostly for older engines. If you are using a good oil, you should not need any additives, as the add packs in the oil itself should be just fine. Zinc has a by product which is ash, this can build up in cylinders, cats, O2 sensors etc causing problems...
Old Jun 21, 2009 | 02:46 AM
  #45
fccs's Avatar
Ams oil ftmfw
Old Jun 21, 2009 | 05:21 AM
  #46
Z28usmc's Avatar
The only 2 oils I use in all three of my cars are either AMSOIL or Royal Purple. The only 2 filters I will use are Wix or Mobile 1. There are many studies out there but the ones I have seen put the products I mentioned at the very top. I'd stay away from Fram filters too- EVERY study I've seen shows that FRAM is overpriced garbage!!
Old Jul 7, 2009 | 03:09 PM
  #47
firechicken99's Avatar
would there be any issues running mobil 1 0w-30 instead of the 40???
Old Jul 7, 2009 | 03:29 PM
  #48
DSkyles's Avatar
I get free penzoil platinum from my work (Jiffy Lube). Since I bracket race it, I change the oil about every 800 miles. I usually either use AC Delco or Wix filters. Depending on what is available.
Old Jul 7, 2009 | 03:45 PM
  #49
Noxious's Avatar
Penzoil Platinum 5w30 winter 10w30 summer. You can get 5 quart jug at wal-mart for $20. Just buy it in the 5qt size and measure it out and you save quite a bit. Run a decent filter and put six quarts in instead of 5.5 if you do any driving where long heavy turns are involved.
Can't beat the protection vs. price.
www.bobistheoilguy.com
Royal Purple is junk btw....Just go to that site and do some research. And DON'T use additives.
Old Jul 7, 2009 | 04:58 PM
  #50
crainholio's Avatar
It depends on what you're doing with the car. As bad as Mobil-1 5W-30 is known for turning into water at high temp/load, their 0W-30 is worse.
