question about valves and cleaning heads
needless to say i would like to remove the valves, clean the heads, and reinstall valves. im not sure what would be the best way to clean the ports and chamber, but i figure an engine cleaning brush and some degreaser should do the trick. with the valves, i think i would just use a drill and grey scuff pad.
as long as i keep the valves in order can i just put them back in, or would they need to be recut, or machined, or do they need to be lapped in?
these heads have less than 5k miles on them since they were milled and had a valve job on the stock valves. thank you
1. Gasket Remover (~5$)
2. Scrape to remove large pieces of gasket
3. Scotch-Brite Pad (This won't hurt the heads)
the scotch-brite pads work amazing btw
