what a lsl 243/251 sounds like
the cam is a lsl 243/251 110+4 .624/.624 11.68 scr
http://videos.streetfire.net/video/2...dle_690054.htm
it is the comp lsl lobes hyd. as it says 243/251 @.050 and no it will not clear a stock bottem end. i have like .150 deep flycuts to get the needed safe clearance
exh was not that bad but needed quit a bit but the intake with the 106 icl needed a ton it was comeing past tdc at over .300 lift if i remember right
