finished build finally!
Old Jun 18, 2009 | 06:25 PM
00 black ss's Avatar
Default finished build finally!
so after jumping back and forth about cams and different setups i finally choosed one and got the setup built. here is the setup
ms3 on a 112 with prc valvetrain
pacesetter coated lts
pacesetter ory
flowmaster muffler/magnaflow catback pipes
ls6 intake and stock ported throttle body
slp lid and smooth bellow
ssra
4.10s
Big thanks to J and T auto for the gear install and a special thanks to member Iverson387 for doing the cam and bolt on install. the car is getting tuned on tuesday by vettetech on long island.
Old Jun 18, 2009 | 06:29 PM
Black FormulaLs1's Avatar
make sure that you post pics of the build and the finished product with the dyno sheet!!! and how much do you have invested in it?
Old Jun 18, 2009 | 07:11 PM
dont have pics of the build but when its tuned ill post up the dyno sheet. i would say i have around 2-4k approximately into it including parts and labor.
Old Jun 20, 2009 | 03:56 PM
actually deffinately more like 4-5 grand i have invested in it. 3 more days for dyno results! how much is most people making with a similar setup? how much power should i make around?
Old Jun 20, 2009 | 08:49 PM
HWI's Avatar
HWI
You need a cut-out so that crapmaster muffler doesn't hold you back.
Old Jun 20, 2009 | 10:05 PM
i have a cut out just didnt put it on. do you guys think its worth putting it on? i know the flowmaster cut out is crap but is it a different muffler they use on the cat back or same one?
Old Jun 21, 2009 | 10:34 AM
Zach79Z's Avatar
Yes run it with the cutout open when it is dynoed. Itll have WAY better numbers then through the flowmaster
Old Jun 21, 2009 | 05:21 PM
Would I make it to 400 at the wheels without the cutout? How much more will the cut out add if I put it on?
Old Jun 21, 2009 | 09:19 PM
Lt1Porsche's Avatar
your gonna need that cut out to hit 400+
Old Jun 21, 2009 | 11:26 PM
Juicy J's Avatar
I would say you should be in between 405-415hp with open cut out depending on what dyno you are on. The Flowmaster will hold you back quite a bit.
Old Jun 23, 2009 | 06:12 PM
car made 386rwhp and 343rwtq on a very humid day and this was on pull number 6. hes going to change some things and wait till it cools down and try again. im hoping to get 390-395. i would really like to hit 400 but im going to need the cut out for that.
Old Jun 23, 2009 | 06:25 PM
Zach79Z's Avatar
Nice. Cant wait to hear the final numbers
Old Jun 23, 2009 | 06:27 PM
vsocks1's Avatar
Do you have plans to put some nice heads on that car?
That should wake it up quite a bit!
Old Jun 23, 2009 | 06:40 PM
Yes I plan on doing heads,spray,rear and suspension in the future. Is the 4.10s holding some power back also? If so how much?
