Can an LS1 be stroked to 377 ci?
The whole idea is to recreate a modern version of the engines that lifted the front wheels off the ground through all four gears. Seriously, that's how light the real Grand Sports were!
They were crazy fast.It has to be an all aluminum V8 like the 377s specifically built for the Mecom racing team by GM. I'm really stoked about the possibilty of this.
http://www.grandsportcorvette.com/gs/gs002.htm
377ci can be 400 block with 350 crank. I am not sure though if GM had 400 SBC blocks back then, they were in production cars in 1970 and beyond.
a bigger bore block would be absolutly sick w/ that crank and a solid roller. can you say 8500 RPM all day long? {/bench racer}or you could do a .080 over iron block, and a stock crank ~ala cheaper.
If you were to use the Eagle 3.90" stroker crank in an LS1/LS6 block that would give you about 373 cubic inches which is close to what you are looking for.
Eagle said that the cranks/rods (they can supply pistons too, JE I think) should be available any time now. According to the catalog they gave the cranks list for $1095.
how would someone go about getting ahold of one of these (phone number, email, web site, etc....)?
My personaly opinion is you get a shop to build you a 4.08" sleeved block, then you get less shrouding, better chambers/flow on your heads, etc. you could probably get 480rw w/o too much trouble.
