Newb on heads cam
Old Jun 21, 2009 | 03:34 PM
chevguy86's Avatar
Default Newb on heads cam
I was looking at the heads cam package which consisted of TorquerV3 cam and PRC stage 2.5 ls6 heads can anyone tell me how good this setup is on the street? My car is not a dd and its a m6.
Old Jun 21, 2009 | 06:21 PM
John02Hawk's Avatar
Depending on what supporting mods you have, you should have no problems with a decent tune getting 420-440rwhp.. What are your plans/expectations for the car? You will lose some drivability with that setup..
Misc. links for reference:
https://ls1tech.com/forums/dynamomet...3-90-90-a.html
https://ls1tech.com/forums/dynamomet...uer-v-3-a.html
https://ls1tech.com/forums/generatio...uer-v-3-a.html
Old Jun 21, 2009 | 06:30 PM
chevguy86's Avatar
I have SLP lts and tds ptb and plan on doing a ls6 intake how much drivability are we talking about?
Old Jun 21, 2009 | 06:43 PM
John02Hawk's Avatar
2300-6700 RPM Power Band with a peak around 6400rpm; This is an excellent performance camshaft with a rough idle!
http://www.texas-speed.com/shop/item...d=669&catid=44
Even with an awesome tuner, you will lose drivability at low RPMs. EX: Cruise control at 75MPH in 6th gear..
With your car not being a DD, I wouldn't worry too much about it..
Read this: https://ls1tech.com/forums/generatio...-v2-vs-v3.html
Old Jun 21, 2009 | 06:59 PM
chevguy86's Avatar
How bad will drivability be if i install the v3
Old Jun 22, 2009 | 07:26 AM
slt200mph's Avatar
You and that cam will not be happy campers unless you run 4.10 gears with it...
