Red/Brown Plugs (Pics inside)
I pulled the stock Delco's after 42k and they were reddish brown, I tried searching around and found mention of a "spark plug coloration guide" but couldn't locate the guide.
I took some pics and wanted to know what you guys think, I run a 75 dry but have only gone through one 10lb tank in the past 8k miles.
***EDIT***Yeah I should have mentioned, I bought that car around 25k and haven't run any octane boosters but always put in at least 91 octane.
![](http://i112.photobucket.com/albums/n170/mymarkVII/IMG_2902.jpg)
The red/ brown color is metal particles in octane boosters, i forget what the name of it off the top of my head. but ill look it up in my text book tomorrow.(Methyl cyclopentadienyl manganese tricarbonyl (MMT) and ferosene Its what makes the fuel harder to burn?
Kinda how lead in leaded gas is a higher octane. But octane boosters do it in a much cheaper way that no where as good as leaded gas>
It will slowly plug up your cats(which no one cares about anyways) And O2 sensors. Ive heard of it building up in the ring lands causing issues but i have never seen it in person . So might be a myth
hmmm mine looked exactly the same when i pulled them about a month ago thought they were normal since my car only has 9,000 miles on it and they were delco plugs. the red did look a little off to me so im subscribing srry for the lack of help dude
check that just did a quick goggle there is an additive in unleaded gasoline that will do that but says its fine though so im not gonna sweat it unless some1 knows better
