How critical is piston deck height & quench distance for an LS1?
6600 rpm clutch dump of death Administrator
Originally Posted by 2000RATA
I hate to be a dick but J-Rod you did not write that yourself. That is word for word from I believe SpeedOMotive's website. I'll have to look tonight to be sure. Own up to it, you copied and pasted.
Chris
Chris
Like I said I'm not being a dick. I was just trying to razz you a little. I should have used the approiate emoticon to express that. I met you at the shootout. It's all good.
Chris
Chris
Chris
Chris
![Punch](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_punch.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Like those????
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Glad to see you guys have a good handle on this.
I keep quench between .035-.045 max.
& I would also recomend Cometic gaskets. They have gaskets from .025 - .125 thicknesses & will custom make them for your application if neccessary.
Originally Posted by John B
93Pony, with this being the case should I even bother decking the block? Should I just get a custom head gasket to obtain the desired 0.035"-0.045" depth and not worry if the pistons are 0.004" in the hole?ghhhh
My new motor has the pistons .005 IN the hole. I bought .035 Cometics to get the right quench.
Which ever way is cheaper IMO....both ways will work.
My pistons ended up being .010 out of the hole, and I run a .041 gasket. Great octane tolerance, zero problems so far with detonation. Motor runs great, despite the poor heads I have on there
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
