Slight tick????
Old Jul 11, 2009 | 05:23 PM
therobman's Avatar
Default Slight tick????
this goes with my other thread i had a throttle body blade screw sucked up which caused the blade to stick open, so when i pushed the clutch in it bounced off the limiter at 6700 for a few seconds before i shut the key. well i got the screw out and now i have a slight tick, its deff up in the valvetrain its either a bent pushrod or a lifter. i had stock pushrods and stock lifters they had 40k on them. i was thinking either i bent a pushrod or a i had some valve float maybe and the lifter needs to pump it self back up i didint have time to pull the pushrods today. what do you guys think
Old Jul 11, 2009 | 08:30 PM
therobman's Avatar
Old Jul 12, 2009 | 12:21 PM
therobman's Avatar
no ones got any imput
Old Jul 12, 2009 | 01:14 PM
99RTA's Avatar
<gets out xray vision goggles> hmmmm interesting
Old Jul 12, 2009 | 01:18 PM
crainholio's Avatar
Over a week ago you said you were going to remove the pushrods and check for bends.
You going to do it, or are you just here to whine?
Old Jul 12, 2009 | 10:31 PM
CW00BlackTA's Avatar
You need to run a compression test on the cylinder that had the screw to make sure you don't have a bent or damaged valve. Then check the pushrod.
Old Jul 14, 2009 | 07:11 PM
therobman's Avatar
well checked all 16 pushrods they couldnt be any more straight . i was gunna throw back on the rocker arms and the valve covers and run it and see if the tick goes away im hoping the lifter will come back up if it is that . any suggestions
Old Jul 14, 2009 | 07:24 PM
therobman's Avatar
ill also add its deff a tick and its up in the drivetrain when i reved it you cant hear the ticking. so the ticking didint get faster with revs it went away but then you could hear it when it when back to idle
Old Jul 14, 2009 | 08:11 PM
mook99ta's Avatar
Did you try this?
Old Jul 14, 2009 | 09:12 PM
SOMbitch's Avatar
The puzzling thing to me is you stated the ticking didn't get faster with revs........
Post a video if you can....
Old Jul 14, 2009 | 11:36 PM
therobman's Avatar
ok i will first thing tomorrow im going to try a compression test after i let it run for a little
Old Jul 15, 2009 | 04:07 PM
therobman's Avatar
well no video but an update put the rockers back with the valve covers ect and started the motor. had the loud tick let it idle for about 15 mins and came back to it, still ticking but now half as loud. let it cool then took it for a 10 min drive, it drove perfect no missfiring, stumbling, felt as good as ever came home got out and listened to the motor and the ticking is even quieter, still there but almost gone. so im going to take it for a half an hour drive later if i have time and see what happens. so i guess its just a lifter thats a little stuck???????
Old Jul 15, 2009 | 04:37 PM
crainholio's Avatar
What oil are you running, and what filter?
Old Jul 15, 2009 | 05:25 PM
therobman's Avatar
stock lifters with about 40k on them and 10-30 synthetic
Old Jul 15, 2009 | 05:27 PM
crainholio's Avatar
What filter? F-I-L-T-E-R. Oil filter.
Old Jul 15, 2009 | 05:32 PM
93blcZ28's Avatar
why would the oil filter matter?
My car does the same exact thing im almost sure i have a bent pushrod. i got another set with 40k on them ive been meaning to throw them in but havent had the time
therobman's Avatar
um a c delco and i checked all the pushrods
Old Jul 15, 2009 | 05:36 PM
crainholio's Avatar
Cheap oil filters that don't flow well can contribute to valvetrain noise. He's running a Delco so not likely it's the cause.
Old Jul 15, 2009 | 05:54 PM
blades11b's Avatar
with the way your saying its getting more and more quiet every time you drive it and what not im leaning towards a lifter man. mayb when that screw went down it got caught in a valve causing some tension on one of those lifters. should have bent a pushrod but maybe it just jacked the lifter all the way down and stuck it there and its trying to recover.. thats my guess
