help
Old Jul 13, 2009 | 02:29 PM
Mrs.Nos's Avatar
Default help
have a 98 ta.
comp. cam 224 228 534 537 @112
410 gears
fast intake 92 and 94 mw tb
comp. roller rockers
3000 pink conv.
And the best time is 13.13 @105 with i 1.82 short time
why the low et numbers
Old Jul 13, 2009 | 02:58 PM
brooksphilip's Avatar
tune? should be going faster than that?
Old Jul 13, 2009 | 03:09 PM
bjamick's Avatar
Wow has it been tuned yet? According to the trap numbers it's making about stock hp. Something is definitely up here, take it to a dyno and have it tuned by a reputable tuner.
Old Jul 13, 2009 | 03:12 PM
TooLateVTEC's Avatar
Too steep of gears, but it should still run faster than that.
Has the car been tuned?
Does it noticably run bad?
Old Jul 13, 2009 | 03:23 PM
2002 SS's Avatar
WOW very low MPH your trapping for a cammed car... must be the tune?
Old Jul 13, 2009 | 03:27 PM
Mrs.Nos's Avatar
It has been tuned. It made only 315hp and 294 torque. It does run good, the power drops of fast at 6200 on the dyno. What would be some thangs to look at.
thank you all
Old Jul 13, 2009 | 04:03 PM
Fuel filter, spark plugs, wires.
Thats almost STOCK RWHP...something is seriously wrong.
What valve springs are on it?
Old Jul 13, 2009 | 04:13 PM
2002 SS's Avatar
^^X2 i ade more HP stock! better get it checked out ASAP. maybe cam wasnt installed correctly(cam gear, crank gear not aligned)...
Old Jul 13, 2009 | 04:33 PM
00MaroonZ28's Avatar
Holy crap that's very low.
How many miles are on the motor? You might need to get a compression check on the cylinders. Sounds like one could be dead.
Old Jul 13, 2009 | 04:36 PM
Mrs.Nos's Avatar
springs are comp cam honeycomb
Old Jul 13, 2009 | 04:40 PM
Mrs.Nos's Avatar
162,000 on the motor, I know, I know, thats alot, your all probably gonna say there ya go, huh
Old Jul 13, 2009 | 04:59 PM
bjamick's Avatar
Nope, I wont say that. Have you done a compression check to see how bad it is at those miles? It may be time for a fresh hone and new rings and bearing and be done with it .
I'm thinking the cam is off a couple degrees maybe. Who tuned it?
Old Jul 13, 2009 | 08:08 PM
Mrs.Nos's Avatar
no commprission test yet, i will no names on the tune. see if we can fix it, any help?
Old Jul 14, 2009 | 11:01 AM
Mrs.Nos's Avatar
what should the compression be?
Old Jul 14, 2009 | 12:45 PM
bjamick's Avatar
Your compression numbers should be 155-180psi. Your really looking for them all to be right around each other.
Old Jul 14, 2009 | 05:49 PM
Mrs.Nos's Avatar
compression test all between 160 to 175
Old Jul 15, 2009 | 09:51 AM
bjamick's Avatar
So you did a compression test? What were the numbers for each cylinder?
