pushing coolant help!
Old Aug 9, 2009 | 01:02 PM
99RTA's Avatar
Yes the cap could have fixed it!
Old Aug 9, 2009 | 01:09 PM
99RTA's Avatar
Originally Posted by LS6427
You just baught the car? Sounds like the engine may have blown head gasket(s).
Short of doing a leakdown check....I would remove the t-stat, start the engine while cold and top off the coolant, go for a drive. If it still boils over when you come back from a 30 minute drive....gaskets are most likely what it is.
It could also be something caught up in front of the condensor, making it run hot as *****, then the coolant sprays out the over-flow, then the air in the system later on boils over. But you did say your temp guage always looked good. You could have a bad temp sensor too.
maybe you could suggest a few more things? LMAO where do you come up with this stuff?????
