head cam needs?
Old Jul 17, 2009 | 08:32 PM
franksaltz28's Avatar
Default head cam needs?
ive been puting together a head cam ls1 for about three months now and i have most of the supporting mods. right now i have ported ls6 heads, ms4 cam, and supporting valvtrain upgrades. im going to spray a 150 wet shot with it so i know i need bigger injectors. what else am i going to need, and what size injectors am i going to need. thanks for any help.
Old Jul 17, 2009 | 08:44 PM
'02 WS6's Avatar
I assume you have a ported oil pump and timing chain? If you're planning to spray I would get 42lb injectors.
Old Jul 17, 2009 | 09:12 PM
black01_WS6's Avatar
also may want to look into a racetronics fuel pump. and make sure you have all the safety stuff for the N20. wideband would be a good purchace.
Old Jul 18, 2009 | 12:42 AM
Got the ported ls6 oil pump and im getting a double roller timing chain. I was thinking about the fuel pump, but didnt know what to go with. I 42 lb injectors going to be big enough with the spray? Oh and the n2o is going to be on a window switch and a wot switch.
Old Jul 18, 2009 | 02:46 AM
jetlag's Avatar
The Racetronix kit is awesome and well worth the money! Don't forget the hot-wire kit.
When they say the kit comes with absolutely everything you need, it has EVERYTHING you need. Racetronix even includes a paperclip to pop out the wires! (you will understand when you see the instructions)
Order from ThunderRacing since you are in LA. They have great prices and keep plenty of Racetronix stock.
Old Jul 18, 2009 | 11:05 AM
yea im getting everything from thunder racing, and getting it tuned by geoff. so do i need just the racetronics pump ***. or do i need the wirering ***. to.
Old Jul 18, 2009 | 12:32 PM
'02 WS6's Avatar
Just get the full Racetronix Kit. From TR it's like $250, and you'll be set.
Old Jul 18, 2009 | 10:58 PM
is there anything else while im on the subject.
Old Jul 18, 2009 | 11:03 PM
TheLSgun's Avatar
Rear end?
Old Jul 18, 2009 | 11:31 PM
Originally Posted by TheLSgun
Rear end?
8.8 custom
