What is everyones take on the AFR heads?
AFR's are "OK". I had a set on my LT1's, they flowed well but GTP at the time was offering a much better flowing cylinder head. I think the heads will be another somewhat affordable option with comparible performance, but judging from what I usually see with AFR's stuff it's not going to be anything out of the ordinary that Craig @ GTP or TEA couldn't do.
JMO of course, from what I have seen in the past.
Josh
From talking to AFR they think they have them pegged for power production.Expecially low end torque production and have tested them against big name Stage 2 ported heads.Everybody has got to remember that Flow #'s do not mean everything.Most of the ported Heads out there could support 700hp motors but the rest of our setup doesn't.So maybe lower flow #'s and higher velocity might make more power on our setups?
I'll hopefully be testing some early release AFR's soon.That will give me the answers needed.
On the other hand the more power the better so I cant wait to start seeing some of the dynos of ls1's with these heads on them.
. Unless the LSX saves us, better flowing heads are gonna be limited by our LS6 intakes, too
Until there is a proven intake, it's going to be hard to realize the potential of the great heads we have now.. much less something that claims to be better. I'm seriously thinking about sticking a 6.0 iron block with a TSP231/237 cam, PP LS6 style heads and the new Edelbrock (that's been ported for the heads) carb'd intake into my 86 firebird that's currently running a mild 406 and a TH350.. that would rule out the "restrictive intake" variable. The Best V8 Stories One Small Block at Time
No more lifting heads for the hi horse power guys.
I think it will be interesting to see what happens, between folks porting raw castings and folks flowing their ported versions.
Cstraub
Well I know you have to pay to play,,, but lets say these heads really do average 20+ rwhp more than the average ported ls6 head which if I am thinking right is what they advertised. That would mean that I need new heads hahaha and I really dont feel like buying another 2 thousand dollar set of heads. I guess I'm just poor
Don't get me wrong I am stoked about all the stuff happening with the ls1 now.
Elec water pumps, new intakes, and even these heads I will just feel bad about having recently sunk money into my current heads which if the afr's turn out good will render them somewhat worthless.
short turn radius and good flow numbers at low port volumes,plus
ying yang yates style double quench chamber we will see significant
gains especially under the curve.Our heads are 15 degrees fords are not
we will make more power with equal combinations.With a free flowing
intake and the 225 cc afr heads you would have a very potent combo
on a big inch motor.Any of our sponsors who port our heads will be able to pull
some more air out this casting with all the material in it to work with.
