Not All 224 Camshafts Are Equal... Engine Dyno Data INSIDE!!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Just curioius about something: when you swap a cam on your dyno mule, do you also use the specific valvetrain parts recommended by the cam's original supplier? Do you degree it into the designer's ICL? It's been said many times by many folks (including TSP as I recall) that it's the combination that is important.
It's not just the tool, it's how you use it that counts.
BTW, that is the most sanitary dyno room I have ever seen. Geeze, at least leave a wrench or shop towel lying around.
Keep that pump hot doing research.
Jon
Jon
We do make every attempt to set the valvetrain up according to the retailers design (we stock Comp and PAC springs for example to try and cover all the bases...we test different diameter pushrods and different wall thicknesses as well in this effort as well as shimming the springs and setting different installed heights when called for). We have been degreeing each cam into to multiple ICL's (ours and competitor's) to ensure a level playing field. I can tell you that some competitor cams we've tested make better average power by a nice margin at an ICL other than their recommended setting as well!
Not everyone designs for highest average power or average torque in the rpm range used by the driver/owner. If they did, max hp number might suffer...how could they then brag/sell the cam?
Gosh, the car might be quicker with better average numbers, but some folks would rather have a bigger hp number than a quicker car. That blows my mind, but I hear it too often. I guess it's like having a larger unit...even if it doesn't work as well it looks good!
As far as specific valvetain parts, that's probably more critical when you get to high BMEP high HP high rpm (also high $) engines closer to the edge of the envelope vs. street-type "224" Umbilicus cams. Isn't that the name of the latest/greatest 224 LS cam out there? I can't remember where I heard heard that name...somewhere on the net. Not yours is it?
FWIW, some cams are very difficult to find. That's not the same as being scarce.
Jon
Jon
Being very difficult to find used and scarce in the LS1 world are more similar than many would like to think!
