Lg Motorsports
Old Nov 17, 2003 | 07:57 PM
02RED Z's Avatar
Default Lg Motorsports
All I Can Say Is , D#@m , Lou , And Jeremy Are Great . They Can Sure Tune A Car . Drivability Is Great . G5x2 , Mti Stage 2 Heads [must Be The Holdup] And All Bolt-ons 419 Rwhp & 390 Rwtq .
Old Nov 17, 2003 | 08:08 PM
CWK's Avatar
CWK
Yea, the guys at LG are great they tuned my car that day also, drivabilty is great, Thanks Lou, and Jeremy for the great tune.G5x2, HP HEADS(HOME PORTED BETTER KNOW AS HIGH POWER HEADS), LANES DUALS AND ALL THE BOLT-ONS 447RWHP/407RWTQ.
Old Nov 17, 2003 | 08:10 PM
SmithZ's Avatar
O2RED Z I have to agree. I made a little more, must be the Patriot LS6 heads I used! And the X3
Old Nov 17, 2003 | 11:30 PM
redc4's Avatar
Dang man, I expected the MTI heads to make a little more power than that. Still not bad by any means. Keep in mind that these are numbers for an A4 car. It will probably make a little more with some more miles on it. We can always hook you up with a set of these Tin Shed Racing heads
Old Nov 17, 2003 | 11:36 PM
99 Black Bird T/A's Avatar
Something doesn't sound right on that. With that cam and all bolt on's you should do way better than my mild heads and cam set up.
Old Nov 18, 2003 | 02:22 AM
wicked 98z's Avatar
NIce numbers, They are close to what I put down with my MTI heads. To bad my motor was fixing to blow or im sure I could of pulled way over 400 with a good motor. Expecially with the 3600 vig
Old Nov 18, 2003 | 09:09 AM
poolfanatic's Avatar
Badass pool player
I don't think that the heads are holding you back at all as MTI's heads are known to be performers. 419 RWHP in an A4 car is pretty healthy - that equates to about 449 in a M6 when you figure in the extra driveline loss in an automatic.
Nice numbers!
Old Nov 18, 2003 | 10:53 AM
DVST8OR's Avatar
02RED Z - are those the new stage 2E heads or the 2R's?
Old Nov 18, 2003 | 11:47 AM
Chicago Crew UnderBoss's Avatar
Don't forget that if the car in question here is a A4 those are very stout numbers and as we all should know by now a A4 (especially with stall and gears) will dyno significantly less than a M6 car.
GREAT NUMBERS!
Old Nov 18, 2003 | 12:05 PM
SNAXS's Avatar
Well My heads were not all that great either. We had my car dynoed with MTI S2's and X1 Cam and all bolt ons and the results were:
393 RWHP
373 RWTQ
That was in my 02 SS A4 with 19K miles.
I ran it at the track before the Head Cam I ran a 12.6@108-9 and after the Heads/Cam it ran a 12.3@112. I then added a monster stall and other major goodies and that puts me where Im at.
Another thing, we recently took apart the motor and the mechanic had my MTI heads flowed and he told me he really wasnt to impressed the way they flowed and a local porter's heads outlflowed mine by quite a bit.
Old Nov 18, 2003 | 01:25 PM
WS6snake-eater's Avatar
SmithZ, what did you put down. I'm going with that same setup? PP stage II's with 59 cc's and g5x3!!1
Old Nov 18, 2003 | 01:50 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Complaining about 419 rwhp through an automatic? Quit dyno racing!
Old Nov 18, 2003 | 02:24 PM
SmithZ's Avatar
Snake-eater, 444.9hp and 403tq Locked #s
PP heads, X3,all boltons,4200 stall built tranny
12bolt rear and 4.10 gears. Pretty good I thought.
Old Nov 18, 2003 | 02:33 PM
I've got a stock 10 bolt w/ 4.24's and 3600 stall, with built tranny. I hope I can beat ya.
Old Nov 18, 2003 | 04:07 PM
ne14a6t9's Avatar
419 through an a4 in a vette is very good, vettes wont dyno as high as you f body guys, thats probably a 430 in an a4 fbody, then you add an electric pump and make 5-10 more
Old Nov 18, 2003 | 04:48 PM
Nytmare's Avatar
That electric water pump garbage is a waste of money, I've talked too a least 5 head/cars that own it ! That is great#'s for an auto! The thing about mti is ( Not a nut-grabber, I personally like LG & Frutral ) they probably won't dyno like everyone else, but they will kick your AZZ on the track!!!
Old Nov 18, 2003 | 08:16 PM
02RED Z's Avatar
The heads were not stage 2e . By the way this was on Lou's high reading dyno .
