Does anybody have their intake off?
Old Nov 17, 2003 | 08:42 PM
ta12sec's Avatar
Default Does anybody have their intake off?
If anybody has their intake off could you please measure the distance from the back of the block to the cowl?
thanks in advance.
Old Nov 17, 2003 | 09:01 PM
jrp's Avatar
jrp
SN95 Director
should of aske me last week, i had everything off during my head swap. why dont you just take your intake off, it dont take but an hour to take it off and reinstall it.
nice firehawk you got
Old Nov 17, 2003 | 09:05 PM
Damian's Avatar
LSX Mechanic
Are you concerned with clearance on pulling the motor? Or custom intake?
josh
Old Nov 17, 2003 | 09:06 PM
DaleMX's Avatar
How about another reference point. I have my manifold off, but its in a kit car. Maybe to the front of the head or something.
Old Nov 18, 2003 | 12:39 AM
ta12sec's Avatar
josh
Not planning on pulling the motor, But I just read the new i/c vette magnacharger is shorter then the regular one, I think it might fit? I just want to get some measurements.
If you can do it so guick go out and tear it off Ill time ya
Ill get to that I was just figuring 1000s of members here someone will have their intake off,
thanks for the complement too
dale thanks but I dont think theres any thing elses to refrence to, unless maybe from the back of block to the top of valve cover at a 90 degree.
Old Nov 18, 2003 | 02:38 AM
onyxxtreme's Avatar
I will do it in the morning for ya
too cold out here, and big hairy creatures lurk in the yard during the night, out here in the sticks
Old Nov 18, 2003 | 04:00 AM
10secondZ's Avatar
From the valley cover to the lowest hump in the cowl is 7.5" and from the back of the block to the cowl is 8 1/4" damn i am bored lol it's 5:00 am and im measuring my cowl lol...one thing i was thinking is...shim your K member down a little?..me and a buddy of mine where looking at this with an australlian root's blower for the monaro's...could be onto something..anyway's good luck!
Old Nov 18, 2003 | 08:45 AM
ta12sec's Avatar
10 I could hug ya.............if you were a chick.
thanks
Old Nov 18, 2003 | 09:50 AM
10secondZ's Avatar
lol no problem man...hope it all work's out..and if you do it get some pic's of the install! but shimming the K member down 1/2 inch should give you plenty of clearance...just use some 1/2" steel plate,cut the hole for the bolts and trim the plate to the size you need...it should work flawlessly...and there is no need to adjust anything else since it would only change your pinion angle about 1 degree and the drop isnt far enough to damage anything suspention wise either..Best of luck to you bro,
Carter
