Bigger Valves ?
Old Nov 19, 2003 | 02:12 PM
Nytmare's Avatar
Default Bigger Valves ?
Will bigger Valves ( from 2.02 too 2.04's) hurt lower
end torque ? What are the Pros & Con's of these
valve choices in stg.2 LS6 Heads ( besides flycutting
the pistons) ?
Old Nov 19, 2003 | 05:42 PM
Cal's Avatar
Cal
No they won't hurt low end torque, but remember the bigger the valves, the more weight they have which leads to the need for stiffer valve springs and can result in lower reliability. Note that GM chose to use light weight hollow valves for the LS6 heads. Also, at some point the valve gets shroulded by the cyilinder walls so you really need a bigger bore to go with the really big valves.
Old Nov 19, 2003 | 06:12 PM
Beast96Z's Avatar
I believe that anything bigger than 2.05 on a stock CI motor is going to start shrouding the chamber. If you stick with the 224, I don't think you will have to fly cut. Always good to check though.
Old Nov 19, 2003 | 06:25 PM
Cstraub's Avatar
A stock 346 incher does not require the a large valve area. The 202 should be suffiencent.
Cstraub
Old Nov 20, 2003 | 12:34 AM
Nytmare's Avatar
Thanks, but fellas, don't let my sig fool you . That is the old set up! The new set-up is, well a set of good heads and a cam ! Don't push me on my set-up please ; because others i'm trying too run are vewing this forum. With that info , do you still have the same position ?
Old Nov 20, 2003 | 09:50 AM
Cal's Avatar
Cal
You can order 6.0 liter ported truck heads that have the same ports as LS6 heads, but have the chambers welded up to get compression rather than being milled off. That will give the best P2V clearance.
