Wanna' be able to remove a valve spring in 20 seconds flat?
Old Nov 20, 2003 | 06:54 PM
Scalpel's Avatar
Default Wanna' be able to remove a valve spring in 20 seconds flat?
Check it out here:
https://ls1tech.com/forums/showthrea...473#post847473
Oil does touch the valvesprings so this does belong in the "Internal Section"
Old Nov 20, 2003 | 06:58 PM
2001 Pewter WS6's Avatar
Restricted User
You could cut that time down with an air ratchet...
Old Nov 20, 2003 | 07:02 PM
Keith's Avatar
And there is no problem with the steel tool on the aluminum of the head? If not, that is one awesome tool!
Old Nov 20, 2003 | 07:06 PM
JoeDirt's Avatar
I just bought one too, it came very quickly and is a nice quality peice
Old Nov 20, 2003 | 07:29 PM
Scalpel's Avatar
Nope, no metal on metal problems. And that is the ugliest can I have ever seen, lol.
Old Nov 20, 2003 | 08:08 PM
EVIL's Avatar
i was just thinking the same thing.....looks like a damn alien!
Old Nov 20, 2003 | 08:15 PM
Tally TransAm's Avatar
it is a great tool, thats why ive been posting the dimensions to it for nearly a year so people could make their own for free. oh well, guess i could have made a few bucks if i hadnt just tried to help out
Old Nov 20, 2003 | 08:22 PM
jrp's Avatar
jrp
SN95 Director
nice . took me 3 days to do my spring swap the first time with that shitty autozone cut off tool. never again. im using the SDPC tool now and have never looked back
Old Nov 20, 2003 | 08:52 PM
Bink's Avatar
Thanks for the heads up. Nice and simple. Brilliant.
joel
Old Nov 20, 2003 | 09:07 PM
Cal's Avatar
Cal
YES, of course this works well! This is exactly the same thing as taking the cheap Napa autoparts spring tool and cutting off the handle then grinding the lips flat. I've been killing myself trying to tell people this is the best way to go, but I guess the vid clip is more convincing than anything else. And BTW, if you don't grind the lips off, the Napa tool WILL scratch the heads!
Old Nov 20, 2003 | 09:12 PM
Cal's Avatar
Cal
Amazing, I've often thought it would easy as hell to make one of those, but I never saw your post with the dimensions! It should have been a sticky . . .
Old Nov 20, 2003 | 09:40 PM
BergerMan's Avatar
The tool seems to work ok, but I don't like the idea of NOT pushing straight down on the retainer. Its a good way to shoot a keeper somewhere where you can't find it.
Old Nov 20, 2003 | 09:47 PM
Scalpel's Avatar
It works more than ok, it's flawless. We have swapped over 40+ valve springs with this tool in the past week w/out a hitch. Works perfectly everytime. To avoid a keeper shooting out, don't use an air ratchet to try to expedite the process. Just use a ratchet and crank it down. Trust me, the keeper won't fly out anywhere
Old Nov 20, 2003 | 10:25 PM
jrp's Avatar
jrp
SN95 Director
i assume the hole for the bolt to go is just slightly larger then the bolt diameter. the problem with my autozone tool was that there was way to much play with the forks sliding around the retainer and not compressing down straight and moving. it was a bitch.
Old Nov 20, 2003 | 11:14 PM
Slowhawk's Avatar
LS1Tech Sponsor
I second that.I've been ussing this style compressor for a while and it is the *****!!I have a couple different ones with different size cutouts to fit tight on different retainers.
Old Nov 21, 2003 | 08:05 AM
John02SS's Avatar
I used the tool from Larry and my 918's were cake. I don't even dread spring swaps anymore!
Old Nov 21, 2003 | 08:19 AM
ever see this pic floating around
here it is again incase anyone feels like making their own
