Compression ratio?? Need advice please
Old Aug 6, 2009 | 10:25 PM
sspower23's Avatar
Default Compression ratio?? Need advice please
I have a stock Ls1 346ci engine and Im planning to get texas speed PRC LS6 stg 2.5 CNC ported cylinder Heads. After adding these heads, what will the COMPRESSION RATIO in the motor be?? This will help Me pick a specific camshaft for the heads, any help please, thank you
Old Aug 6, 2009 | 11:35 PM
borderguy881's Avatar
im intrested in this myself...how much affect does valve relief have on it?
Old Aug 6, 2009 | 11:39 PM
02*C5's Avatar
Depends on how much the deck is milled and I think that's a costumer choice and what gaskets you end up using?
Old Aug 6, 2009 | 11:50 PM
sspower23's Avatar
PRC LS6 stg 2.5 CNC ported heads are 64cc
Old Aug 7, 2009 | 09:39 AM
Spd-Kilz's Avatar
Fairly certain it will be ~10.5:1
Old Aug 7, 2009 | 01:16 PM
slt200mph's Avatar
Call texas speed and ask them they build the heads.
Old Aug 7, 2009 | 02:47 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
With the stock short-block and GM MLS head gaskets you can get them at 64cc chambers and that will net you about 10.7:1. Of course thinner gaskets and milling can bump your compression up from there!
What camshaft were you considering?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 8, 2009 | 12:24 AM
sspower23's Avatar
With those PRC LS6 stg 2.5 CNC heads? The Torquest camshaft from the following is what I will use:
215/231 .631/644-118lsa
232/234 .646/.612-112
235/243 .621/.624-113
239/242 .649/.609-112
Which one is the Torquest camshaft for those heads??
Thanks
Old Aug 8, 2009 | 12:52 AM
hammertime's Avatar
Thanks
Why limit it to those choices - especially the first one? Your first selection is similar in profile to the CheaTR, a compromise cam for stock like sound with a stock exhaust. All the rest tend toward the mid-upper range.
You've really skipped over the lower 220's cams that will really make some torque at useable rpms.
