Compression and pushrods
Edit* Just for reference, my setup is the same as in the signature still, Torquer V.3 with the only new addition being the milled heads and some LS7 lifters.
>You need to measure for pushrod length, you'll probably need shorter than 7.400
>Also you need to measure your piston to valve clearance as you are on very, very tight clearances. I estimate less than .04x
>and last .029 gasket is a bit too thin since you are now in .022>.024 range quench (too tight)
