Cam only, low numbers??
Old Aug 25, 2009 | 11:39 PM
  #81
tittan1500's Avatar
Originally Posted by RiceEaterZ
Cam only TrickFlow stg III, put down 388/373ft-lbs, I have since Swapped my ShitMaster that came on the car with a 3" Magnaflow catback and a Cutout so lets call it 400/375.
swap that intake and you'll gain 15-20hp and port your tb if it isn't already.
I love how all of the M6 guys post there numbers like there god.... apples to apples guys he has a high stalled auto with tall gears your numbers will be nothing alike just like the track times!
Old Aug 26, 2009 | 07:45 PM
  #82
SidewayzOZ's Avatar
Yeah half the posts in this thread was crap like..
I got x cam i made x hp.
Lots of help that does.
Any updates RedRocket?
Old Aug 26, 2009 | 08:33 PM
  #83
RedRocketZ28's Avatar
Yeah...Patrick said that my cam should make peak power around 6300 and peak torque around 4800. I have the ford red top injectors which I thought would be fine for my application. What else would cause the power to fall off if the cam is installed right?
Old Aug 27, 2009 | 05:05 PM
  #84
SidewayzOZ's Avatar
That's where I thought it should have peaked. I'm at a loss on this one as to why it peaks early. You should have plenty of injector, and your intake/exhaust setup doesn't seem like that would be the bottleneck. You may have to start a new thread in this section to see if you can get some of the more experienced guys to step in and take a look. Just make sure you put everything you can in the thread so you weed out all the pointless comments/questions.
Old Aug 29, 2009 | 07:50 PM
  #85
Fatbum's Avatar
I made 364rwhp/326lbtq in my A4 LS2... with a cam spec'd by FTI to make 400rwhp. I LOST 1/lbtq by adding Cam/Headers/3200 vig stall and only gained 30rwhp.
It was a 224/228 .610 .612 w/ 112+4lsa
Did you install a UDP with the Cam? Did you purchase a double roller adjustable timing chain and did the shop that did the install degree the cam in?
The shop that did my install didn't degree the cam in and the tune sucked.
I'm taking it to a new shop in the next few weeks and will share how much of a difference I gain
Originally Posted by Blknight6989
Alright guys so I finally got my 4k stall an gears installed this past month and had a cam swap done at the same time.....and Im PISSED!...I was hoping for the car to put down close to 400rwhp however figured it wouldnt due to the automatic as well still having the ls1 intake on there. However the car only ended up putting down 354 hp to the wheels. Help me out guys, am I overreactingg and does that sound right or is there something wrong?
The cam is a custom spec from pat G and the specs are 231/235 with I believe a 600/601 lift or so. I had the springs an pushrods and all supporting stuff put in along with the cam and had it dyno tuned. Im also dissapointed in the fact that the car has only done a 12.4 witht he 4k stall,3.73 gear, panhard,sfc's,lowercontrol arms and eibach drag springs in the front. This was launching the car at 2k rpm and dead hooking on M/T dr's.
Sorry I know that part isnt part of internals but my main concern is why this doesnt seemt to be doing what it should! Help me out here guys, the person who now does my car and builds grudge cars says it could be the tune, me and him have discussed it and are thinking of switching out to the g5x4, having a different place dyno it and throw a 200 shot at it for next years racing season if noone has an idea whats wrong here! Thanks for any responses and sorry this is so long Im just really frustrated about the performance
