oil cooler setups? lets see them.
My cooler:
the fitting goes the pan and the lines go to the rad. although u could plumb the lines into a convetional oil cooler.
the 6.0 truck cooler lines would work fine with a aftermarket oil cooler
http://estore.websitepros.com/212053...N+DAVIS+RACING
I would run a thermostat as well and you will need either a sandwich type plate or the LPE block adapter. Canton has a nice thermostat and LPE has a nice block adapter. You will need to make a few lines or have some made as well so you'll need to account for fitting too.
The LPE block allows for a temp gauge as well and has another accessory hole in it.
but ill see what i can find and ill post it as soon as i find it http://www.noid.org/oilcooler/
Also Lingenfelter makes an adaptor.
Yep that's the LPE plate I was talking about Unit is designed to be mounted and plumbed in-line between the radiator and water pump. Measures 10" long x 4" wide x 4.5" tall
They come in dual 14 plate and 7 plate as well.
Geesh! You've gotta get yourself the biggest baddest cooler and 8 qts of german Castrol.
Good luck against those Nine eleven Turbo's...
i took care of buisness
i wouldnt have kept messing with him had i noticed it had got so hot. but i honestly didnt look until after we ran the third time. then i **** myself and told him i was done. coolant temps were only 190 though. and its like 198 degress in florida.
