oil cooler setups? lets see them.
fwiw, when i did my tranny cooler setup on my fbod, i used the 11x8x1.5 b&m stacked cooler. i live in SE texas so it gets hot and humid as hell here. i modified that radiator support area (the upper part where the air filter sucks from) with a crescent wrench by gently bending it back creating a little extra room, and a less obstructed path for incoming air to boot.. i pushed the cooler up in there with the fins running vertically (i have pics somewhere.. but im not real sure where as i didnt find em, sorry) anyhow, my tranny never even got over 150* with this cooler. (i had a yank PT3800 and Drag radials.. and i was all about smokin the fkk out of em) Due to this i added an oil cooler thermostat to keep the fluid temp up around 180. but it never even so much as crept the tiniest bit over 180. the cooler had a 28000 GVW rating i belive.
you could run a similar setup for your oil system. in the past, ive put an oil cooler on EVERY engine ive built, and on cars that ive purchased that didnt already have one. so far ive had great success and luck using them , and am really a believer in their use. the B&M's are badass coolers for the dollar. im a big fan of the quality and the performance. even the smaller coolers seem to do really well.
on my 331 in the pushrod notchback stang, i even dropped coolant temp by 10* by adding an oil cooler. the 96 cobra i had was also plagued by overheating issues from the factory, the oil cooler helped in that regard as well.
just my experience
Not bad for repeated WOT runs http://www.noid.org/oilcooler/
Also Lingenfelter makes an adaptor.
The LPE block allows for a temp gauge as well and has another accessory hole in it.
Lots of good stuff from Mocal and Setrab here.
Here are some pictures of my set up. I'm still in the process of building the car up, but this should give you an idea.
I wasn't even aware that Mocal part even existed.
I need to get my Kooks long tubes installed, then see what I've got in the way of room to install one of these adapters.
