I need some help....Cam questions??
Unfortunately, we do not have enough information to know if it is mechanical or tune related. If pushrod length is off, or the cam was not degreed, or anything else that can go wrong in a cam install would put you down in power.
Don't apologize for a newbie question. I would be also be panicked after installing a cam and not knowing if the install or tune was off. My best advice is to get it on a dyno one way or another and check it out. Otherwise you will just be guessing.
Good luck.
..WeathermanShawn..
