question on fresh motor
Old Aug 14, 2009 | 01:20 PM
transam19's Avatar
Default question on fresh motor
just freshened up my motor and went to start it last weekend and my oil pressure is up the roof. its reading like 80 psi. could it be a bad sensor. i have a tsp ported oil pump. just a cam only car. what do u think am i ok. i havent really let the car run for while cuz i get paranoid about the oil pressure
Old Aug 14, 2009 | 03:16 PM
98RedBird's Avatar
Swap the sensor first, then go from there.
Old Aug 14, 2009 | 03:33 PM
transam19's Avatar
sensor is brand new from gm
Old Aug 14, 2009 | 11:59 PM
SchuttsR1's Avatar
That high of oil presure isnt bad on a fresh build.
Old Aug 15, 2009 | 10:46 AM
ss69's Avatar
Happened on mine. I've got a melling 296 pump. When I first started it, it was was just about pegged the guage. New sending unit. I've got about 8k miles on it now and it sits about 45-50 at hot idle and 75-80 WOT.
Old Aug 15, 2009 | 11:03 AM
slt200mph's Avatar
You have great oil pressure go drive and enjoy your new engine...it is time to rock and roll ...
Old Aug 15, 2009 | 11:04 AM
slt200mph's Avatar
Old Aug 15, 2009 | 02:19 PM
transam19's Avatar
ok thanks guys for the answers
Old Aug 15, 2009 | 03:34 PM
98RedBird's Avatar
What did you set your bearing clearances to? That's probably why it's higher if the sensor is new and working correctly. If that's actually how high it is there's really no problem. Oil pressure is a very good thing lol.
Old Aug 18, 2009 | 05:46 PM
transam19's Avatar
well just wanted to make sure cause i have read that guys here have problems getting oil pressure on start up and i had mine really high. i had just put new bearing from clevite. i didnt really do much just bought new bearing cause my crank was still good and put new one's on to stock spec.
Old Aug 18, 2009 | 05:56 PM
crainholio's Avatar
What clearance did you measure with the new bearings, at the mains and rods?
Old Aug 25, 2009 | 03:34 PM
transam19's Avatar
all the bearings were put to stock spec cause my crank wasnt that bad when i took it out. the crank actually looked good just had it checked and polished.
Old Aug 25, 2009 | 04:23 PM
crainholio's Avatar
Sounds like maybe you didn't measure clearances.
You could have just gotten cash from the ATM and burned it, at least you would have had some warmth to show for your investment.
Next time at least use PlastiGage and get a decent clearance measurement on all the mains and rods.
Old Aug 25, 2009 | 05:52 PM
BigRich954RR's Avatar
Make sure you run a good oil filter some of the cheaper one will blow apart from the hi psi.
I like moble1 / wix / few other just cant remember them right now.
Old Aug 26, 2009 | 11:55 AM
transam19's Avatar
everything was checked with a plasti guage. everything was done to factory spec cause the whole bottom end is stock. so i dont know where ur getting that i didnt use a plasti guage. y would i do a fresh build and not check for clearance. every rod and mains were dead on to spec.
Old Aug 26, 2009 | 11:56 AM
transam19's Avatar
just still trying to break in the motor. but will be using some better oil and filter.
Old Aug 26, 2009 | 05:22 PM
crainholio's Avatar
Great. What clearances did you measure with the Plasti?
Clearance specification is a range, not an integer value.
If you've put a few miles on it, might be a good opportunity to remove the oil filter, cut it open, and spread out the filter media to look for metal flakes.
Old Aug 26, 2009 | 11:34 PM
hammertime's Avatar
What kind of engine assembly mube was used? Lubriplate and other assembly lubes are thicker to maintain an adequate oil film until startup. Your pressure could drop a bit after you reach operating temperature, perhaps even more after you drop the break-in oil. As long as you aren't pegging the needle (pressure relief appears to work) you should be fine.
