i need help
Old Nov 23, 2003 | 07:34 PM
cb's Avatar
cb
Unhappy i need help
i have a 98 ta with 136000 miles on it and im burning oil. i go to college so i dont have a big budget to spent. i was wondering what yall suggest. at the most id like to spend 2500 to 3000 . thanks
Old Nov 23, 2003 | 07:42 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How much oil is it using per 1000 miles?
Make sure that your oil is not low, check it regularly.
Might want to try putting a new pcv valve on and seeing if that helps.
Old Nov 24, 2003 | 07:09 AM
niphilli's Avatar
Also what kind of oil are you using? If you are using synthetic switch to non-synthetic. Try a heavier weight oil (10W30 non-synthetic). This may not help if you have major consumption, but this with a new pcv system will most definately help.
Old Nov 25, 2003 | 12:12 AM
cb's Avatar
cb
im using valvoline VR-1 racing.
Old Nov 25, 2003 | 07:08 AM
niphilli's Avatar
Sounds like a synthetic. Switch to a 10w30 non-synthetic first, then look into the PCV sys. PSJ was talking about above. If neither of these work then your rings are probably toast.
