243 or 799 heads?
LS6 243s had light weight valves.
LS2 243s had regular valves, same as 799s. They are the same... some Corvettes even have one 243 and one 799.
2005+ LS2 and LS4 (front drive G-bodies) used the 243 casting, but with standard valves. The 799 used a different casting process than the 243. In my opinion, the 243 is the better casting (stronger, better machining).
I have never seen a Corvette with 2 different cylinder heads but you are correct the LS2 has regular vavles I was only referencing LS6 243's.
