Need a good cam to get over 400+ hp
ok been reading alot about cam's and found one that was interesting...I dont know if you guys every heard of chris but he's on youtube with just a 230/230 cam and made over 420+ hp that amazing. These engines are amazing at making so much hp just out of a cam...trust me wont be buying until I take everything into consideration. All the help you guys have been is great. I have to take a look into the f series cams but I think the ms4 is to big an I want my motor to at least last alittle longer.
That cam will put a
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
im also in the market for a cam as well. this thread has pretty good info on it.
is there a cam to make 400 on cam only with out having to rev to 7000?
what about the torquer v2?
chrs1313's signature
silver 02 z28 A4 3.23 gears
Custom ram air, 85mm Lid/MAF, ported 92/92, cut-out, SFC's, ASP 25%, LCA's, drag bar, front qa1r, body mount tq arm, SS4000, QTPs with ORY, 275 M/T radials 230/230 111+2
409hp 373tq
Stock Internal with SS3600
11.558 at 116.24 MPH 1.546 60ft DA -832 11/25/07
Cam Only and SS4000
10.811 at 122.67MPH 1.386 60ft DA -400ft Race weight 3250-3300lbs
409hp 373tq
Cam Only and SS4000
I'm not saying that you won't also have great results, only that they don't happen by accident. Attention to detail is the key to making big numbers with good manners.
LS1 Tech Administrator
I take down all your info and spec you a cam based on your mods and goals. You can then have the cam ground by one of my preferred vendors (board sponsors here). They have excellent package pricing so you won't pay too much.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
ok check this ok guys I was at the track last night an I met this guy with a 04 gto which has ls1 this guy just had ls6 springs , pushrods an a hot cam an only a 100 shot this guy was doing mid 11's all day stock interenal that really got my juices flowing if you know what I mean. On that note the best I did was 13.1 at 110 just on 273 gears I think my motor is running real strong cause man last night It was trying to rip my head off ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
hey patrick let me know what I need so you can spec a cam for me
LS1Tech Premium Sponsor
We have tons of engine dyno data from testing camshafts of different sizes and specs. Give us a call & we can discuss your goals. Just because a camshaft is custom spec'd for your car doesn't actually mean it's the best camshaft. We don't just spec camshafts for a customer we think will work, we spend hundreds & hundreds of hours dyno testing camshafts one after another looking for accurate data we can use to build the best possible camshafts for our customers.
We can build you a custom spec camshaft, the difference is we're using actual experience to spec you the perfect camshaft. If you'd like us to provide you with a bunch of dyno sheets comparing different camshaft ranges your looking at give us a call! We can definately help point you in a good direction.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#33
Click the link in his signature that says "For custom camshaft help press here."
#34
HUGE cams don't always equal the fastest track times. My cousins cam only car (228R) runs high 11s. Check out his race with the red car and read all the mods on both cars...he wasn't spraying either.
http://madtunesracing.com/
#35
As John posted above, our RapTR cam will get you there easily but I could also spec you a custom cam as well. There are many options out there. Some vendors here would have you believe they are the only shop that does R&D. I can assure you, all reputable shops test multiple combinations in various vehicles to come up with cam specs. We've been in business longer than most shops on this board and years longer than many. Its funny how everyone has their "OWN" lists of cams that look almost identical. Everyone has to start somewhere but we started from scratch. We've tested hundreds of camshafts over the years and have seen what works and what doesn't. It's easy to take someone else's hard work and R&D and try to improve upon it. While others are taking our 10 year old designs to compare against, we've gone in a completely different direction. As a matter of fact, over 70% of the cams we sell today are not even listed on our website (for various reasons...) Why not contact each vendor and see who gives you the best service and technical advice? Thunder has a long track record of providing excellent customer service with race proven parts and unparalled technical support. I've said it before and I'll say it again here, I'd rather lose a sale than sell you substandard product, PERIOD.
Also, as stated above, the biggest cam doesn't always make for the fastest car...
Thanks,
Shane Burgess
Co-Owner
VP Operations
Thunder Performance Group, Inc.
d/b/a Thunder Racing
Thanks,
Shane Burgess
Co-Owner
VP Operations
#36
You guys are right the biggest cam is not the best with alot of reading all day I think I have come closer to what I want which is mostly in the 230 area cause I was thinking to my self why put a huge cam just put a cam to give close to the power I want then just throw like a 100-150 shot of nos. The rear I wanna see how long it will go before I crack the hell out of It. Later plan to put a strange in it with 3.90 or 4.10's. Trust me looking around for the best deal I can get times are tough right now but If I want it get it.
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#37
You guys are right the biggest cam is not the best with alot of reading all day I think I have come closer to what I want which is mostly in the 230 area cause I was thinking to my self why put a huge cam just put a cam to give close to the power I want then just throw like a 100-150 shot of nos. The rear I wanna see how long it will go before I crack the hell out of It. Later plan to put a strange in it with 3.90 or 4.10's. Trust me looking around for the best deal I can get times are tough right now but If I want it get it.![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
