Need some advice on an ls6 based 402 motor....
Hey guys, lookin for some advice... I'm looking at doing a:
ls2 block
tsp 402 rotating assembly
custom cam
ported 243's
ls6 intake (for starters, eventually step it up to a fast 90/90)
about a 150 shot of n2o
and of course all the goodies such as injectors, fuel pump etc. etc.
now my question is... what size dish pistons should I go with? Or should I use flat tops? and is anyone running a similar setup? if so, what are the goods? the bads? any recommendations would be much appreciated. keep in mind, i'm not on much of a budget, but i don't want to go all nuts droppin cash.
ls2 block
custom cam
ported 243's
Last edited by IWGF; 08-23-2009 at 11:14 AM. Reason: Good god, I accidentally said ls6 rather than ls2. Whoops!
ls6 block
custom cam
ported 243's
ls6 block
custom cam
ported 243's
Try to find pistons with 2>2.5 cc valve reliefs, that gives plenty PTV clearance for good size cam without milling the heads too much, keeping compresion in the 11>11.4:1 ratio.
I'm partial to Wiseco pistons for price and quality
And some sponsors sell bearings and rod bolts with the assembly for less then 2000.
