No compression on 1 bank
Old Aug 28, 2009 | 07:42 AM
H8TO WRK's Avatar
Default No compression on 1 bank
I am just finishing my install. It is a 05 LS6 from a CTSV into a Jeep if it matters. I had it running for 1 min then it shut down and will not fire again and I am getting a back fire through the intake. I thought a tiing issue so I checked and I am dot to dot. I have not been able to check the crank position sensor yet but I found another issue
I put a compression tester on Cyl 1 and got nothing I mean nothing then I checked all on the Drivers head and no compression on any of them. could this be a head gasket issue? Im not sure what else. I did not have the heads off this motor but it looks like I am going to pull one.
Compression on the other side it fine.
Old Aug 28, 2009 | 07:50 AM
ccrider's Avatar
do you have an air compressor? put some air in a cylinder and listen for the air leaking,that'll help narrow it down
Old Aug 28, 2009 | 08:00 AM
H8TO WRK's Avatar
yes I can and will try that, thanks any other ideas?
