Valve Spring suggestions
Old Aug 31, 2009 | 02:13 AM
millerw's Avatar
Default Valve Spring suggestions
Im looking for suggestions on which valve springs to get for the installation of my comp cams Custom grind 237 INT 244 EXH .610 INT .644 EXH 112 LS on my 01 WS6. Any help would be appreciated im new to ls1's
Old Aug 31, 2009 | 03:25 AM
jetlag's Avatar
PAC 1518, maybe?
Old Aug 31, 2009 | 08:15 AM
slt200mph's Avatar
PRC Extreme duals (.700 lift) ...with that size lobes you are going to need good control of your valve train.
Old Aug 31, 2009 | 11:17 AM
millerw's Avatar
would these work safely? https://www.patriot-performance.com/...0&cat=0&page=1
Old Aug 31, 2009 | 01:27 PM
slt200mph's Avatar
You need 50/1000s over the lift of the cam for your spring ... you listed .640 lift on the exhaust lobe...that is why I suggested the .700 lift PRC Extreme springs. What is the application for this big azz cam??...one place you do not want to cut corners is in your vavle train especially with a large cam.
Old Aug 31, 2009 | 01:46 PM
WSsick's Avatar
Originally Posted by millerw
yes but id go with these:
nothing wrong with a little bit of insurance when running a big cam. peace of mind never hurt. some people even run duals on low 230s cams.
Old Aug 31, 2009 | 02:14 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Without a doubt you should consider the new PRC EHT springs. They're a complete redesign from the platinum/gold/xtreme springs old stuff. They are built using much better material & as a result have been tested to have greatly longer life & they won't shrink when installed on increased lift camshafts.
For the money the EHT PRC spring kit is worth it's weight in gold. If your on a budget the new .660" PRC spring is a redesign that's still a good bit better than the old platinum or extreme springs. They were redesigned to not have shrinking issues at .650", but they won't last as long as a EHT spring.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Aug 31, 2009 | 05:17 PM
JPH's Avatar
JPH
Use a "proven" dual spring setup imo. That camshaft profile would prefer that.
Old Aug 31, 2009 | 06:33 PM
02*C5's Avatar
^^^^ ALWAYS go with 50/1000 over your total highest lift number. You will have assurance that you won't run out of spring specially if your running an M6 set up and miss a shift or something, you don't want to have your springs maxed out when you hit hit the rev limiter.
Old Aug 31, 2009 | 06:43 PM
bearcatt's Avatar
Originally Posted by jetlag
PAC 1518, maybe?
I like those too alot.
But the poster has a BIG cam.
The duals might be better.
I have a good deal on a set of some of the best valve springs made.
https://ls1tech.com/forums/lsx-parts...l#post12151077
Old Sep 7, 2009 | 06:05 PM
millerw's Avatar
Im not really finding many options for a .700 lift without having to moddify the spring pockets. Can anyone point me in the right direction?
Old Sep 7, 2009 | 06:54 PM
WKMCD's Avatar
I run PAC 1521's with more lift than you. Expensive but the best drop in spring you can get.
