Scraping off head gasket material
What should I use to scrape the old head gasket material off with? I have a Crapsman metal gasket scraper but am concerned about it gouging the block. Is there anything other than this scraper I can use?
TIA!
www.ls1howto.com should mention what we used.
chris
I WOULD NOT SUGGEST USING A SCOTCH-BRITE PAD BECAUSE OF THE SMALL PARTICLES OF GRIT THAT ARE IMPREGNATED IN THE PAD THAT CAN GET INTO THE CYLINDERS, THAT IS NOT GOOD!
For a metal gasket, I can't say as I've not used one. Probably best to get the surface very clean at that point, and a plastic ice scraper first, with a 2nd pass CAREFULLY with a flat edged razor would probably do the trick.
have had no problems with the new gaskets leaking or anything.
