Any advice on cam selection.
Also any guestimates of "hours to install" on these cars would be great too.
Thanks.
this kind of thing comes up at least 10 times a week.i suggest a custom grind. something around the 228ish range will be great for what you want, very drievable, and through an auto 390ish rwhp should be easy (would be 400+ through an M6). also, correct me if im wrong, something like a 110 or 111 LSA will bring the powerband down so you dont have to spin it so high and there is plenty of low end. just find a tuner that knows what hes doing with that kind of LSA. do you plan on adding a converter at all?
To the OP, your current supporting mods don't lend themselves to any of the flavor of the week cams around here. Are you planning for headers and a stall? If so, you should probably do the headers first, then save up for stall/cam/tune all at once.
If you're asking what cam works with a stock A4, Stock stall and stock exhaust manifolds, there are several out there, but you must keep a few things in mind:
Stock A4's don't like to shift above 6100-6200 rpms. The more you rev it, the shorter it's lifespan will be without some upgraded internals.
Stock converters are already a limiting factor for these cars, and a cam with a decent amount of overlap will need to idle fast enough to pull through the stock converter.
Stock exhaust manifolds don't like any positve overlap, power production will begin to fall off as you pass beyond negative overlap with increasing duration or decreasing lobe separation angle.
There are several directions you can go, but more info is required to make any valid suggestions.
I guess the voice of reason would say to just stall it and throw some long tubes on. I 'd want to go catted y with a fairly low stall.
If this is truly your daily driver, what mix of city and highway driving do you drive? For a mostly highway car, you may not notice a big difference in fuel economy. If you do a lot of stop and go driving, be prepared for your mileage to take a hit.
What is your ultimate goal? Make some more power? Turn a certain ET? Just amp up what you already have? Be honest with yourself about how you use your car, and choose your mods wisely - you be much happier in the long run.
). In all honesty et is not really important to me I guess, since I have no way to measure it. Just looking for a little more of what I already got is all. Thanks again guys. Are Hotcams really worth it? 1.) Long tubes and catted Y
2.) Pulley
3.) Test pipes or cut-out's (if the first step isn't loud enough, either of these are easy to reverse)
4.) Ditch Diablosport/SLP tune for a good dyno/drivability tune
At this point you've made your car marginally louder at cruise, but it should give a little extra thrill when you mat the gas. In the process, you can gain 25-30 rwhp, and give up little to no fuel economy at light throttle, where your daily driver lives.
The last steps you can make with minimal compromises include intake swaps and or a head swap. Here your budget will largely dictate the results. Switching to a FAST intake can gain you a few more HP, but doesn't necessarily come cheap. Bolting on some stock LS6/243 heads should get you another 15-20rwhp, while aftermarket castings can step up from there, up to around 30 or so rwhp. It would be tough to make much more without a camshaft.
From here, a mild cam that works around the stock auto and converter could gain you another 15-30rwhp, and shouldn't stink things up too much. Expect to lose some of your city fuel economy though, 10% to 20% depending on the size of the cam.
On the otherhand, a converter will get you a much better holeshot, at the expense of a 15% to 30% reduction in city fuel economy (again depending on how high the stall is). You should notice a nice SOTP improvement, provided you can put the power down.
Any of the above would best be combined with tuning, so you may opt to do them as part of the 4th step above. Of course heads, cam, intake and a stall would be ideal, but at some point, it's easy to go overboard, and we are still talking about your daily driver.
If you throw your credit card or check book at your car and do everything you can in the interest of making it fast without being obnoxious or to friendly at the pump, you could push 380 to 390 to the rear wheels, dip deep into the 12's at a stock weight, and still maintain 90% of the daily drivabilty. A converter will hurt your fuel economy more than a cam, but then a good cam will need more converter
The old adage still applies "cheap, fast, reliable - choose any two"
) since I did notice a nice sotp improvement and better shifts etc. Took off torque management etc. I will go with a 3400 stall with 2.1 str. Heads and cam I'll be doing together of course, so I need to look into how a cheater will work with 243s. How worth it is porting the ls6 castings? Ls6 springs (if they will cut it?), and I'll leave in the stock 323s.Side note: what's the best way to increase tranny longetivity? Built 4l60e? Or 4l80e? Just wondering for future reference.
So.... if I go with lts, catted y, stock slp catback, same lid/intake man, 243s (maybe ported), hotcam or cheater cam with springs, I should have a good daily driver with a little extra zoom right?
Thanks again guys, some of this work will have to wait till next spring so I'll start with the bolt ons. Maybe a ported tb and pulley if money permits, but definitely lts.
