TR230 cam, what valve springs?
Old 03-11-2010, 12:45 PM
5.3LJimmy's Avatar
If you have a straight spring(not beehive) on there now then you will need to get a set of stock or titanium retainers to fit the 918's. But personally I would use a dual spring to help stabilize the valvetrain with the heavier rockers. If you go the 918 route I would recommend getting some shims to set the install height .050" from coil bind to maximize spring pressure. BTW - The higher spring pressure does not decrease HP because there is always a spring closing and opening at the same time and the pressure of the closing spring will assist in the opening the other. That is a common valvespring myth.
Old 03-11-2010, 02:02 PM
LilJayV10's Avatar
Originally Posted by ThunderStruk
I think there may have been a typo in the email. We use the 918 spring. I think the 1 and the 8 got inverted when typing.
Well crap I think I am going to change then.
Old 03-17-2010, 06:12 AM
LilJayV10's Avatar
John,
Could you look at these two manley springs and tell me which one would be better.
the .600 lift spring is 150/355
the .650 lift spring is 150/375
http://www.manleyperformance.com/nic...vetrain.shtml#
Thanks for the help.
Old 03-17-2010, 12:51 PM
Squirts11's Avatar
Originally Posted by slt200mph
PAC 1518 would be a better choice over the 918s...there have been some bad batches of 918s over the years...or your could use patriot gold duals or the PRC duals ....
I believe the Comp 918 issue was resolved years ago. I know I haven't read anything recently regarding a quality issue.
Old 03-17-2010, 03:00 PM
SOMbitch's Avatar
I tend to agree with this or at least 1518's. If that cam made power past 6500 I would say duals for sure.....
Old 03-17-2010, 04:01 PM
72Obsessed's Avatar
The 918's have a .625" max lift. I have the tech sheet from when I bought them. They were redesigned in 07'
Old 03-17-2010, 10:11 PM
SOMbitch's Avatar
I realize that but those HS rockers are heavier and require more spring to control. Not sure about agressive the ramp rates of your cam are but that has an effect on valve control too. But as long as TR knows you are running HS RR's and say it is ok I would be good with it though. Those guys do this everyday...
Old 03-18-2010, 03:30 AM
LilJayV10's Avatar
That's a good point, I don't know if they do or not. I was hoping John would post again but I know he is busy
Old 03-18-2010, 09:43 AM
froman's Avatar
the 918's with the silver nitride finish are the new updated ones.
Old 03-18-2010, 10:00 AM
pitbull14218's Avatar
im about to buy a TR230, i figured 918's would work well, the TR230 doesnt have that high of a lift, shouldnt it be fine without shims?
Old 03-18-2010, 10:22 AM
ThunderStruk's Avatar
Being that the Harland Sharp rockers are a bit heavier than stock, a dual valve spring will probably be a better choice than the beehive springs will be.
Old 03-18-2010, 10:59 AM
  #32
but with stock rockers it would be fine with the beehive springs and no need to shim them either right?
Old 03-18-2010, 11:09 AM
  #33
5.3LJimmy's Avatar
Yes with 918's would be okay without shimming and stock rockers. But it is always good practice to measure installed height and shim the springs to the same height(if needed).
Old 03-18-2010, 01:58 PM
  #34
LSX Mechanic
Damian's Avatar
I installed more sets of 918's the past 2 years than I can remember, and I've yet to have one failure. Comp did have a bad batch 4-5 YEARS ago, but most spring breakages I see are user/installer error.
That being said, if you can get away with a beehive do it. Less weight on the valvetrain is a good thing. The TR230 will run on a single spring properly set up for at least 25,000-30,000 miles without the need to replace springs.
Old 03-18-2010, 02:07 PM
  #35
LilJayV10's Avatar
That's what I was wanting to do. I didn't realize the H/S rocker added that much weight
Old 03-18-2010, 09:39 PM
  #36
thunderstruck507's Avatar
using pac springs on my tr230 wanna be cam
Quick Reply: TR230 cam, what valve springs?
