Cam and Piston selection
Old Sep 18, 2009 | 04:29 PM
02_camaroz28's Avatar
Default Cam and Piston selection
I dont know what kind of cam and pistons to run with a this setup. Its going to be a LS1 stock cubes with stock rods and crank. With a ARP or Katech stud and bolt kit, FAST intake and TB, stock heads, around 3000 stall, LT headers and ORY, and 3.73s
Old Sep 20, 2009 | 02:46 AM
Anybody?
Old Sep 20, 2009 | 03:06 AM
ringram's Avatar
Why stock heads!?
Thats going to limit the usefulness of any cam.
Pistons, just get some flatops with valve reliefs and a proper set of heads first. Otherwise just stick with something small.
Old Sep 20, 2009 | 03:52 AM
IWGF's Avatar
Why stock rods?? If you're already tearing the motor down to drop new pistons in, might as well do some new rods... Port your heads while everything is apart. Have Pat G spec you up something, shoot him a PM. Or Pred Z.
Old Sep 20, 2009 | 12:25 PM
NAAllTheWay's Avatar
i dont even think you should bother with pistons to be honest, i mean they are actually going to cost you power bc of weight most likely, just run the stockers and fly cut them if u need to, i just dont see it worth tearing down the motor for just pistons alone
Old Sep 20, 2009 | 01:47 PM
I was going to leave the stock rods because I have been told they will hold up to 650 hp and im not going to be pushing near that at this time. Im not wanting to put a lot in this car I have other projects.
Im not just tearing down the motor for pistions. Im going through it cause it has 150k on it.
Old Sep 20, 2009 | 01:49 PM
Originally Posted by ringram
Why stock heads!?
Well i know a lot of guys that are running stock heads with cam, intake, exhaust, gears, and stall and running decent times. So the stock heads work decent to some extent.
Old Sep 21, 2009 | 09:29 PM
06tx4.8's Avatar
12 Second Truck Club
call martin at probe pistons. i just ordered my set of SRS Forged slugs from him. outstanding customer service.http://www.probeindustries.com/
Old Sep 21, 2009 | 11:27 PM
Thanks
