Hydrolocked...Forged motor?
First of all to take any sports car threw a flooded area is just not smart, when I first read that I knew it wasnt over. Then when I saw that he did not change the oil after it and decided to run the car, and on top of that he hydrolocked one motor already just screams WTF. If there was water in the cylinders when from what you described there was then It probably got past the rings when it was compressed.
you obviously dont have money to blow if you are concerned about getting insurence to pay for it so why the hell would you drive threw water and then not take all the precautions to prevent damage befor starting again.
If it had been me I would have changed the oil and Filter, took off the TB and intake to make sure it was dry. pulled the plugs and cut off the fuel and give the engine a few dry turn overs and then let it sit for another day, then put everything back together and try to run it the next day. then after that oil had about 20 miles on it I would change it again.
Right about now I wish they had a HERES YOUR SIGN smily on here
But now I got my ins. company to look at it and they totalled the vehicle like I expected due to water coming in the cabin and everything else. So I went ahead and bought it back from them. But I went ahead and changed the oil and no water came out but it was a little milky looking. It looked like as if I would have blown a HG but there is no oil in the coolant. I put some cheap oil in it and am going to let it idle for about 15 minutes then change it again. I can't start the car right now because I live in a residential neighborhood and don't want to sit there and let it idle and **** the neighbors off =0. But there was no water in the intake because I took it off today and inspected it so hopefully all will be good and my car won't be dead.
The vehicle will not be a flood salvage title vehicle anyway from what the adjuster said. They are sending me the money to payoff the vehicle and I will get the title. But since I bought it back he said it won't be a flood salvaged car. I figured it would but they assured me different.
Basically you churned it in when you ran the motor so just give it a few days and it will seperate again. If it wasent real bad the you may have just dodged a bullet, although i would replace all the bearings anyway.GL
